OPC UA With a CM1542 modul ??
userxyz
May 2002
any
2,768
I'm curious if I will find someone who has some experience with OPC UA in TIA Portal :).
With a 1500 CPU you can set OPC UA Server active in the PLC. This way you can acces data with a OPC Cliënt. For testing I used the OPC UA Cliënt from the Siemens support Website, this one works well.
But..., anyone who knows how to acces the OPC UA via a CM1542, it seems unaccessible from that card. We did some tests without succes, on the CPU PN ports no problem, but via the CM1542 no succes..
Anyone experienced the same ?
Thanks in advance,
Kind regards,
Combo
I'm not sure if you can, which seems like a big oversight. The CM is generally used I think it took a couple revisions before you could view the web page over the CM/CP, could be a similar thing.
I was also surprised to see that the OPC server is active on ALL or NONE of the integrated interfaces of the PLC, with no way to be selective.
Found
Well it was in the manual, OPC UA cannot work with CM card, only via the PN port. So we changed by buying a Matrikon OPC Server on the PC side to connect via the CM card to that 1500 CPU. For OPC UA we had to switch the networks else, and that was not logic for our standards.
Kind regards,
Combo
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
224
I know nothing about simaticnet OPC server. I do know Kepware. I would only ever scale raw to engineering in the PLC, but it is possible to scale...
217
If anyone has a crack for IBH OPC Server, please send it to: [email protected] Urgently. Thanks in advance!
129
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
178
Hi good day Everyone, I have a cimplicity v10 project with 7 to 8k tags communicating with AB PLC through OPC and Rslinx classic. I have this...
218
