1794-IE12 module remains flashing after configured
Samueltronics
May 2020
São Paulo
Hey guys, good morning !!
I have a doubt, I'm configuring a 1794-IE12 module using the 1794-TB3G base, using a 1794-ADN with 1756-DNB, the LEDs on the 1756 and 1794-ADN card are OK, but the 1794-IE12 module led flashes green.
Can you attach the program?
Also have you got the devicenet configuration file, with the analogue card in it, and has that been downloaded to the scanner
Zip it first.
Zip it first.
Hello Mark, I had to leave, but when I came back I went to the site, and accidentally blocked my password, I had to create a new user, then I will wait 15 minutes and I will log into my other account and delete this one ... I will attach here the configuration I'm using from RSlogix5000 and RSnetworks.
Attached is the zip file Mark.
We are getting IO module fault on device status of 1794-IE12 module. Please suggest if any solutions.
653
Could someone show me an example on how to wire the analogic input for lets say channel 0 ?? Ive found this manual...
5,230
Hi all, what is the proper way to fuse 1794-IE12 modules? fuse sizes/locations? We are burning up these modules in our facility.
1,721
Good afternoon. 1794-ie12 module available, channel set to 4...20 mA. According to the table from the manual, we get from 0 at 4mA to 30840 at...
2,257
Hi, I have a 1794-IE12 FlexIO module connected via Ethernet/IP to a 1769-L24ER CompactLogix controller. The inputs are configured for 0-20mA and...
2,356
