Beijer Trend only allowing 48 hours of history???
krakenfan69
Nov 2011
Alberta
229
I guys. I have a Beijer T12 panel that was developed by someone else. The trending is only allowing the last 48 hours to show. All the curves in the panel are updated every 60 seconds and the datalogger is set to allow a max of 1,000,000 logs. There are 43 tags the datalogger. Am I just nuts or should I be seeing around 2 weeks of history with those settings? Tech support said it should be working with this setup but clearly it isn't. Can anyone shed a little light on the inner working of the Beijer tending system for me? I'm normally working in AB products.
Thanks in advance for any help,
Kraken Fan #69
Have you checked the available memory? There is a way to use a systemtag to show percentage of memory used.
Also, I think there is a limit to the number of rows you can log. I am trying to find an email from Beijer that stated the number but I must have deleted it.
Hi all, First post here, I hope I'm putting it in the right spot! I have an ancient Beijer E910T which went down today. Given the proximity to...
306
I am looking to upgrade a CompactLogix on V18 to an L83E on V32 which is currently using a Beijer E1151. Does anyone know if the E1151 is directly...
644
Has anyone put together a combination of the Beijer iX Developer software and a Rexroth L54 controller over ethernet? Can't seem to get the...
549
Hi, I'm currently having an issue with a Beijer T70 HMI. We have 2 HMIs talking to a Yaskawa motion controller via modbus over ethernet. The...
578
hello every body. I want to upload program from E100 HMI Beijer. I have " E - Designer " software and CAB5 programing cable. I tried with USB to...
18
3,246
