ACS550 ABB VFD , ABB AC500PLC for paper coating winding unwinding control
Anup29
Feb 2018
Kolkata
Hi Team,
I am working on one Paper Coating machine,
My Winder, infeed, Coater and Unwinder is runnning through ABB's ACS550 VFD,
My winder is working in Torque mode, and other VFDs in Vector speed mode,
Now we are planning to make the complete system as closed loop by putting load cell for winder, and infeed ,
May you help in this case, how should i proceed and how should i control VFD for closed loop,
All VFDs are over modbus communication
Iam getting Fault F021 ("System Fault Current Measurement is out of range"),Any help ??
3,003
I am having problems connecting my L32E to an ABB ACS550 RETA-01 Ethernet/IP Module. AB tells me the problem is with the RETA and ABB tells me it...
2,384
I just replaced this drive as the old one went out when the plant had a power surge/flicker. 1-Installed the drive 2-Powered up 3- Got an...
1,641
Hey all. I tried to startup a drive last thing before leaving for the weekend. On power up, the drive constantly gies earth fault. This is with...
2,203
Please i need help i lost all setup parameters to control 3 pumps pressure i put again some of them but i get stuck in ref 1,2 choice and...
1,440
