Good choice for VFD or servo in a Master/Slave setup
rootboy
Jan 2004
Tennessee
1,375
Hi guys,
What would be a good choice for a drive or servo in a master/slave setup controlling two sides of a lift? The issue is that the lift has to go all the way down to the floor and we would not be able to put a jack shaft in to drive the other side.
So we plan on using two lift motors, which each would have an encoder. Suggestions for the encoder choice would be appreciated as well.
Thanks!
John
Hi, we use the Rexroth drives with Indra Motion and Indra logic. We have built many lifts such as you describe with multiple motors and drives, as many as 8 "axes" that I know of. They work very well, and the customers that we built them for are sold on them. (Aerospace, automotive and others.) I know very little about how to write the logic (they have an embedded PLC or you can use a stand alone PLC with them. The platform is Codesys. I am an A-B user and I'm not familiar with all the setup on them. I've watched others here at my work doing this and it's not too bad. I'm doing a small project with 2 servos now and it has been a challenge for me. These are supposed to be the primo product for motion. They are expensive.
I do NOT work for Bosch-Rexroth. I work for a controls integrator that is a distributor for them. Hope this helps.
I've used Fuji Ace drives in a master/slave setup with great results. The slave drive will get the extra encoder card and all of the functionality is built in based on parameters.
What HP are you looking at? Servos might be more expensive at larger sizes, VFDs with Induction Motors might be too expensive at smaller sizes. But certainly this can be done with either now. In the VFD realm, it's going to be the higher end products, not the inexpensive cheap ones. But do you also need regen braking? That might make a big difference.
Let's say it's for two 15hp motors, it's still in the design phase, but it won't be more than that.
No regen braking necessary.
I'll take a look at the Fuji drives as well.
Thanks for the help guys!
This is the only one that I would go with
they are designed for lifting and hoisting applications not just a label on a standard drive
Every lift is safety check before and after every move, a failure sets the brake and halts the move.
Been using them for years .
http://www.magnetekmh.com/
Marathon Black Max motor dynapar encoder
I took a look at it, and it's more in line with what a crane would need (this is for a standalone vertical lift). The weigh scale feature is interesting, and could be useful to us. I'll call them up and see what they can do for us.
Thanks!
I rarely need to add a network card to the drives we install... very rarely. But my sales-guy said he needs to quote a network-connected ACH580...
2,589
When did FactoryTalk Services get intertwined with ControlLogix? I ask this because I have been on Studio 5000 ver 31 up for a while and forgot...
2,825
I have to put 3 UPS's into outdoor cabs. I thought of going with the ones that are used on Traffic lights and such but that is such overkill for...
2,518
Just curious what other fellow PLC talk members have for cellphones as the one I currently have, constantly drops or just straight up has no...
52
11,726
Hello, Thanks in advance for your input. I am building a simple alarm panel. It has 8 magnetic door switches and 8 corresponding 4mm leds on...
17
3,455
