Good Morning ,
I'm getting ready to take the step of retiring our Windows XP laptops.
We have a number of older ControlLogix CPU's and are using versions 10 thru 20 on some of these Windows XP machines. Wondering if you can help me with a few questions......
- RS Logix 5000 -What versions load up fine and play well with Windows 10 ?
- What are the benifits of using the virtual environment ?
- Is the virtual environment available with Windows 10 ?
- Is XP Mode available with Window's 10 , and if so , does that eliminate the
need to do the conversion of FactoryTalk View applications done in 32 bit , or
it is probably better to convert anyway ?
- What about RS Logix 500. It does not matter what version of RS Logix 500
version you have , I guess it will still communicate with the SLC 500 and
MicroLogix . correct ?
I'm sorry , I know that alot of questions.
Thanks so much for your help.
