FactoryTalk View SE Numeric Input Background Color
habadeer
Aug 2012
NJ
43
Maybe I am missing something obvious hereo_O, but I have been unable to figure out how to change the background color (among other properties) of the NumericInput object in FactoryTalk View SE version 6.1.
If anyone knows how to change this or if you simply can't please let me know.
Thanks!
You can change the text and fill color properties for input fields in the behavior tab of the display settings. This will change the appearance of all the input fields on the screen.
Thanks, boilers38! That was it. Why on earth did they put it there? Oh well.
Next question, is there a way to get rid of the border or at least change its color? Also, the number seems to be left justified. Anyway to change that?
The Numeric Input Properties dialog box has a couple radio buttons for justification. You should be able to choose left, center, or right. Unfortunately, I haven't found a way to change the border color.
Yep, found that, too. Thanks again, boilers38, for the quick responses. I guess I will just deal with the border. At least the background color makes the presence of the border much less annoying.
Not in front of my PC so from memory try
Right click > panel properties then double click in fields next to each property to change
I'm working on converting an old PanelBuilder 1200 HMI application into FactoryTalk View ME. The PLC was an old SLC 5/02 with a scanner card for...
1,102
I'm using numeric input enable link tag to PLC DINT type. What I want is for the example in the panel view user will input 350.568 (and shown on...
1,137
Good Afternoon , I have an older Panelview Plus and do not have the application . I'm in the process of re-doing the HMI application from...
3,875
Good Morning , I'm trying to use a Numeric Input Enable in a FactoryTalk ME application. I have a REAL ( Data Type ) that I would like to...
7,147
Hi all, I'm working on a program with a numeric display field which seems to be capped by a minimum and maximum. This isn't a typical numeric...
3,283
