SCRV Rockwell S-Curve Ramp Function Block Example Code
69FIREBIRD
Oct 2004
New Zealand
102
Hi all, has anyone got a working example of the SCRV S-Curve Ramp Function Block.
I cant seem to get it to run - guessing a parameter is not set correctly.
I can get the RLIM to work but looking for something a little more sofisicated.
Controller is an 5370 L1 Rev 30.012
The only difference I see between what you have and what I know is working in a machine is you have no JerkRate set. I can't quite figure out what Rockwell is saying happens when it is zero, but a higher JerkRate value gets you to your Accel or Decel rate more quickly. I suggest putting a value there, say 1000, just to see.
Maybe someone more familiar with the instruction can shed some light. I use it alot, but I always have a JerkRate programmed with a higher value switched in for a Jog and a lower one (more 'S') for a Run.
Hello guys!! I have an application in which one unrolled sheet steel goes through a process of tension levelling and then rewound. I know the...
2,441
Background for the question: A service man from a sub-supplier has made changes onsite to a Siemens PLC and HMI program. He has not made a backup...
163
Hello all, I am an Industrial Electrician, and deal with a little bit of everything including PLC troubleshooting and programming. When I started...
157
I am working on a large migration of the standard PID instruction to the PlantPAx P_PIDE. Has anyone done a migration like this before and have a...
170
Hi all. What is the purpose of that block (MVM) when used with a 2#1111_1111_1111_1111 mask in that situation? I'm really hoping there is...
174
