Panelview Plus 600 to run on power-up
LMDAVE
Oct 2006
New Orleans, LA
50
I see a selection when download a file to Panelview to run when transfer is complete. But, is there a setting (through software or the Panelview itself) to have the system run on power up, like after a powerloss.
The users of my panelview lost power over the weekend and were lost with just the panelview configuration menu. I need it to go right back into the runtime file on powerup.
The explorer menu on Studio has a "Startup" menu item where you can specify the initial graphic when PanelView boots up. I usually keed the configuration screen hidden or passworded to avoid any "accidental" re-configuration.
Yeah, I already have the initial screen set up from there. My issue is, when you power down the panel view and power it back up it goes directly into the configuration where you have to hit/TOUCH [F2] to run the file. Now that should be simple enough for the user, but they were confused. I wanted it to run the .MER file on powerup without even going to the configuration menu if possible.
IIRC, It is in (or very near) that configuration menu you are describing where you specify to run the application on power-up.
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
459
Hello , I have an HMI of PV+ 600 (2711-T6M5D) Ser A Rev B, This HMI doesn't have the ethernet port i have to take backup through communicate...
652
Hello all, I copied the MER file from one PanelView Plus 600 to another one, using a USB drive. On the new HMI, I copied the MER file to the...
628
Hi all, I have an old PanelView Plus 600 (2711PC-T6C20D8) that I am repurposing on our site - I have flashed the firmware to ME version...
976
Hello Team, I have a question, I have been working with a panelview plus 600. But I have deleted all the .mer directly from the HMI, after that I...
1,697
