Comm error:CTC Powerstation P-1 & Micrologix 1500-1764 LRP Pro
Gem1
Mar 2004
Hello,
I am fairly new to this forum but I am hoping someone could offer some advice..
I am trying to get a CTC (Parker Automation) Powerstation P-1 to communicate via Comm Port 1 RS232 Null Modem with a Micrologix 1500-1764 LRP Proc. I have configured it to use Channel 1 DF1-Full Duplex w/ BCC error detection enabled. I know that Channel 1 is valid as I can communicate in and out of the PLC on it. I also know that my null modem is good because I have been able to download my app into the powerstation with it from my laptop. I am using Machine Shop's Interact Software to design my app. I am tryin to communicate via the Allen Bradley Data Highway Drivers on the Program. I was told to use SLC-5 drivers for the micrologix 1500. I can't seem to get the Powerstation to communicate with the micrologix 1500.
If anyone has any ideas, it would be greatly appreciated.
Gem1
The only thing that looks out of place is the error checking; MicroLogix controllers default to CRC error checking, not BCC like PLC-5 and ControlLogix.
Check the DF1 driver configuration in RSLinx software and it should indicate to you whether CRC or BCC error checking is being used.
Hi all, This is my first post; I am new to PLC Controls stuff and English is not my native language, so I apologize in advance if something is...
509
I have a problem and I can't find anything about it in the Rockwell Knowledge Base. The problem is that I am losing communication with a...
1,237
Hi there, I am doing a site survey for an older plant which my company has started working with. There are mutliple different PLC's around the...
4,434
Hi, All production number reset following the comm error. I've looked through logic and disabled autamatic reset future. The counters should only...
1,926
I am having faults on my Kinetix 6500 servo drives that read Safety Module Communication Error. The system consists of a 1756-L73S Version 20...
3,551
