plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old October 10th, 2017, 01:08 PM   #1
cefisher15
United States
cefisher15 is offline
PLC-5/250 Compute Expression
I've got a print-out of old code (PLC-5/250) that I am trying to decipher. I am hung up on an expression in one of the compute blocks. The block parameters are as follows:
COMPUTE
Dest: NUMST
Expression: I:013{07..00}+(I:013/16<<8)
Can anyone please help me understand what this expression is saying? I can take a picture of the rung if it will help, but that is all of the info from the block.
Old October 10th, 2017, 06:51 PM   #2
daba
United Kingdom
daba is offline
daba's Avatar
Quote:
COMPUTE
Dest: NUMST
I think I have deciphered it, and to be fair it looks a strange one, but to be absolutely sure can you show the bit patterns of I:013 and NUMST after the compute has been executed.
__________________
___________________________
ControlLogix & SLC Training
a-b train ltd.
abtrain@tiscali.co.uk
www.abtrain.co.uk
tel: 07506 73 9999
nil illegitimi carborundem
Old October 11th, 2017, 10:03 AM   #3
cefisher15
United States
Quote:
daba, Unfortunately all I have access to is a PDF file of the code. Attached is an image of the input rung and the compute block. I013 has 16 bits, as far as I can tell, this compute block is concerned with bits 0-7 and 16. It looks like NUMST is an int.
I'll dig through my PDF to see if there's any variable maps, but I seem to have lost access rights to it, so it might take a while... if its not one thing, its another, am I right?
Old October 12th, 2017, 02:32 AM   #4
daba
United Kingdom
daba is offline
daba's Avatar
Working through it, bit by bit....
I:013{07..00} extracts the low 8 bits of the data in I:013, this seems to make sense going by the handwritten notes on the first picture - "Data"
I:013/16 will result in the data being "shifted" towards bit 0, by 4 bits (/2 will shift by one bit, /4 by 2, /8 by 3, and /16 by 5 bits). Then the <<8 will shift the above 8 bits to the left, putting what was labelled as "Index" into the upper 4 bits, bits 17..14, but it also duplicates the upper 4 bits of "Data" into bits 13..12, zeroes fill the lower 8 bits of this partial result.
After adding the partial results together, you get....
bits 17..14 = "Index"
bits 13..10 = upper 4 bits of "Data"
bits 07..04 = upper 4 bits of "Data"
bits 03..00 = lower 4 bits of "Data"
The picture shows the individual operations within the compute. You should look at this when you look at any other operations performed on CCO_NUMST
__________________
a-b train ltd.
www.abtrain.co.uk
tel: 07506 73 9999
Old October 12th, 2017, 09:57 AM   #5
daba
United Kingdom
daba is offline
daba's Avatar
I've just had the thought that the "/" in I:013/16 might be a bit address, not a "divide by".
It's been such a long since I looked at any PLC5/250 code that I can't remember... "Divide by" might be "|" (pipe).
PLC5/250 (Pyramid Integrator) was programmed using the very old 6200 software, I don't know if it ever made it into RSLogix5.
Anyway, if it is a bit designation, it looks like the latter part of the compute "pulls" bits 06..00 up to bits 16..10
Or, the "<<" bit shift might be circular within the destination, so it might be putting bit 16 only into bit 6 location
See if those ideas make any sense.....
__________________
a-b train ltd.
www.abtrain.co.uk
tel: 07506 73 9999
Old October 12th, 2017, 11:33 AM   #6
cefisher15
United States
Daba,
Thank you for your help! Looking at the other rungs of code, I agree that the"/" is a bit address. Taking into consideration your remarks, and what I know about the expected values of NUMST, I think the expression is basically concatenating bit 16 with bits 0-7 to make a 9-bit binary representation of a number, then storing the decimal equivalent in NUMST (see attached).
Old October 12th, 2017, 12:02 PM   #7
daba
United Kingdom
daba is offline
daba's Avatar
Daba,
Your attached image is what I was working towards with bit 16 being "rotated" left by 8 bits, but I think that it would end up in bit 6, not bit 10. In a 16-bit integer, with the bits octally addressed, bit 6 and 16 are 8 bits apart, whichever way you shift.
Perhaps the number constraints mean that it is creating a 7-bit number, with bit 6 being the sign bit ??? EDIT : I meant 7, not 9
Whatever way you look at it, it's a rare piece of programming, I'm sure there would be a better way to do, IF we could understand what it is trying to achieve !!
__________________
a-b train ltd.
www.abtrain.co.uk
tel: 07506 73 9999
Old October 10th, 2017, 11:36 PM   #8
JaxGTO
United States
JaxGTO is offline
I remember the << is a bit shift left
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1756-L62S PLC Faulting when generating safety signature Kalagaraz LIVE PLC Questions And Answers 7 April 11th, 2017 07:45 AM
PLC to replace spark detection/suppression system in LP ducting, good idea or bad? SolarNinja LIVE PLC Questions And Answers 17 January 7th, 2017 10:03 PM
Plc suggestion aec LIVE PLC Questions And Answers 36 January 2nd, 2012 12:56 AM
PC to PLC Protocol TheRixta LIVE PLC Questions And Answers 13 December 17th, 2008 12:56 PM
PLC 5 Compute analog scstroud LIVE PLC Questions And Answers 6 September 26th, 2008 03:57 PM
