AB Micro800 and Connected Components Workbench programming question
CCW HMI tagging
Hello Everyone,
I am using 2711R-T7T. Seems like it has got limitation for tag creation upto 200 only!!!
I got question. If I want to use a single bit of integer for Button action, how can I do that in CCW HMI??
Thanks,
Shailesh
Pretty sure you will want to use an instruction block for this. Such as Binary Operations Category "SHL" or "SHR". I'm pretty new to CCW as well and am coming from using RSLogix and so far have not been able to find any "I/O table with registers" to view the actual bit level operations going on in real time. This is something I'm used to being able to use/view.
Trying to implement the new Allen Bradely 800 series and its software, Connected Components Workbench here at the chicken plant in livingston ca...
5,441
My company built a small test machine using a Micro800 PLC and CCW software. We chose the Micro800 because the machine is very simple. We are...
173
Hi, Is there a way to set the IP of a micro dynamically, based on a variable value.?
170
Anyone use the newer 2080-L50E or L70E with 1734 Point IO yet? I have a customer asking for a setup and I have not found anyone that has done...
390
Is there a way to download the program to a Rockwell Micro810 without using the Rockwell CCW application?
740
