Getting analog output from TSXAMZ 600 card
Raj Kumar
Nov 2003
New Delhi
Can any one tell me the commands/application program for getting an voltage output from the Modicon TSX PLC's TSXAMZ 600 analog card. I am not using any analog input and want to get 0 to 10 volt output by providing digital input to control the output of some power supplly. I do not have the literature also to refer. I am using instruction list language and PL7 programming software.
Hi
Write a value between 0 and 10000 in the %qwX.4 or %qwX.5. X is the position of the analog card on the TSX Rack.
If you go to Aplication Browser -> Variables -> I/O you can symbolise the output (use a frendly name) and see exactly the output adress.
João
What is the actual command ? Is it ST %qwX.4:=xxxxx or S or R %qwX.4:=xxxx
Please write it for me if I want to assign 3000 to the channel 4 of the card installed at position 3 of PLC.....
I never used Instruction List. Always use Structurated text or Ladder Logic, but I believe is something like:
LD %M1
[%QW3.4:=3000]
(you must change %M1 according to your needs)
Hope this hepls
João
Hi, I tried today to get RD3A and WR3A instructions to work on the PLC and it didn't work, but it worked in simulation. I followed the clone...
18
1,396
hi all, i m using L32e controller and 1769-of4vi analog output card... i m not able to get analog output from it.... can anyone please let me...
1,231
Hello, I have a Micrologix 1400 PLC and using RSLogix 500. Using a Multi Ranger Ultra Sonic Level Sensor and the input is moved to N7:11, then...
3,875
Hello everyone I need logic to see the some analog value getting updated or not. If updated to this ,if not updated do that. Will this work put...
1,668
The application was working in Twincat 4022.16 Used VM for offline. recently changed the laptop and the getting the error with Message as below...
52
