FT View scroll list
bbargiel
Dec 2017
KRK
Hello.
I have 130 Inputs in my application, so I would like to create a scroll list with 2 columns. Any ideas? I have FT View ME 7.0
Thanks.
Hi & welcome to the forum
The way I have achieved this before is to map each 16-bit input card (or output card)to an internal register (say a N register if using RSLogix500)and then use one display to show 16 multi-state indicators that are addressed to tag placeholders
This one display is then populated using parameter file(s).
Hope this make some sense - write back if you need more info.
Hi! Did you have some example?
Well, I don't really think that an example will help you understand what I mean. Sorry to be difficult.
Remembering that this site is about learning PLC's
Is there anything that you don't understand in what I posted? For example
  • Map a 16-bit input card to a N register - Can you do this?
  • Create a new display with 16 Multi state indicators with tag placeholders in the connections tab - Can you do this?
  • Create a Parameter file?
  • Call the new display from an existing display, etc?
If you can post something that you have done, then we might be able to guide you in the correct direction
Say I take some MODBUS registers and pull into my Logix plc DINT array (sequential). Now, I get a little fancy… using FactoryTalk View SE 13.00...
18
3,188
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
94
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
77
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
106
76
