1769-OB32 problem
yfcarer
Apr 2006
Tianjin
82
Hi Gents:
I met a problem with one of my 1769-OB32 module. Some of the channels suddenly malfunction -- The light indications for the channel are showing right status for ON/OFF, but the output voltage is wrong. When I force channel off, I can get 24VDC from the terminails, while when I force it on, I can measure 18VDC. Meanwhile, most of other channels are working right, that no voltage when off and 24VDC when it is on.
Any thoughts? Thank you.
Sounds like that output transistor has failed, you can either move the output to a spare that works or replace the card.
I have a Micrologix 1500 configured with a 1769-SDN communicating with 1769-OB32 24VDC output module using a 1769-ADN. The Micrologix reads the...
2,157
Just wondering what other folks have used on their digital output loads when using this digital output module. There will be a number of...
1,070
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
81
I have a CompactLogix 1769-L31 and need to communicate with it. I only have studio 5000 on my computer. However, when I try to start a new project...
390
I have a 1769-L24ER-BB1B and I am trying to flash it to 34xx, its flashing red and faulted, when I try to flash it I get a popup stating it needs...
241
