controllogix Rslogix 5000 V16 online I/O card addition
wilsonzhu
Jan 2008
vancouver
278
Hi all,
Is it possible to add I/O card on controllogix controlnet network online. can I schedule the controlnet online? Further more, can I add 1756_CNB/E online too?, if it's true, I can add one more rack for controlnet online. what's the procedure when add these cards? Thanks.
I'm not sure if ver. 16 has this capability. I know ver. 17 does. Remember when adding I/O to a ControlNet network, it uses the unscheduled bandwith of the network. Therefore no scheduling is necessary.
I believe V16 was the first to be able to do this. You can add a discrete I/O card to an a rack that is configured "Rack Optimize" without having to rescheduling the network. I believe to add an analog card, it will work unscheduled until you have time to schedule the network. I am not sure you can add a ControlNet card though, never tried it.
I have installed rs logix 5000 v 20, and I have a project file (.acd) ehere the controller is 1756-L71..... my software does not contains 1756...
3,855
I have a friend/customer that has a old program, they say its version 8.... anyone have anything they can open it with and print a PDF I can go...
2,684
... more PLC101 questions for you experience Ladder lovers: Do these PLCs boot up with junk values in memory, and if so how do you typically...
7,547
More dumb questions from the 'Janitor: In this program I've been looking through (that I didn't write), I see hard-coded constants which are...
2,795
OK, the "Janitor" here with more dumb questions: I've got an Analog I/O point (AT-13) on a 1756-IF8 module which is configured as a 4-20 ma...
42
12,648
