WinCC Flexible 2008 SetBit in array bit tag
idell
Nov 2009
Bucharest
97
Hi! There is an array tag. MyTag bool - array elements 30, I try to use SetBit function to set one element of MyTag, but flexible doesn't allow acces to MyTag. Project is for KTP1000. Who do know is it possible to use SetBit with array tags in WinCC Flexible ?
thank you ivo.maenen , KTP does not support scripting and it seems that only solution is to create particular tags.
I just get a solution. The goal was to set/reset bit in array bit tag, with simple button (and Set/Reset bit function)is not possible, but using switch element it works well. In this case to operate, for example 30 bits from plc data block, is enough to use 1 tag with 30 elements that means you use only one power tag instead of 30.
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
265
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
106
Hello Friends I have installed WinCC Flexible 2008 SP5 Update 2. I have open the software, but the Transfer option does not appear. Is It...
1,473
I have wincc flex 2008 project made with wincc flexible 2088 sp1 project hmi device is simatic pc panel 19" I want to change hmi device to run the...
17
5,282
Dear experts, I am Muhammad we have an IPC With the windows XP Embedded CE 5.0 on project and running well. i have plan to install wincc flexible...
3,844
