Hi All
Whenever i try to change the IP address of a compact logix PLC from RSlinx, this message appears to me "unable to read module's port configuration. the default values will be shown"
Two of my colleagues are having the same issue from long time till now & they can't change the IP address of any device whether they are connected through ethernet or USB cable.
I tried to uninstall & install studio5000 (including Rslinx) & didn't work, I tried to delete harmony files & didn't work.
Have any of you gone through the same issue before, if yes could pls guide me how to solve it ?
Any suggestions from experts would be much appreciated.
RSlinx version: 3.90
Note: I can ping the PLC & see it on the network. I can also connect/download to the plc using RSlogix5000
