plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old August 25th, 2006, 04:43 PM   #1
TdB
Italy
TdB is offline
Smile Random number generator
Hi guys,
I need your valuable suggestions about writing a module (AWL Step7) generating random integer numbers...
Let's say the users define the range of the numbers and an input (on negative edge) triggers the result...
I did one myself but it's still not true random...
Any ideas ??
Andy
Old August 25th, 2006, 05:33 PM   #2
geniusintraining
United States
geniusintraining is offline
geniusintraining's Avatar
Try searching...
it has been covered many times, I got 40 hits...there are several that deal with S7,
this one looks good http://www.plctalk.net/qanda/showthread.php?t=11354
looks like the majority use a system clock to generate the numbers
__________________
www.PLCCable.com PLC Communication Cables, PLC Trainers, MicroLogix, ControlLogix, Siemens, Allen Bradley and more...OEM and aftermarket supplies... Aftermarket 1784-U2DHP Allen Bradley USB to DH+, new USB to 485 modbus
Old August 25th, 2006, 05:51 PM   #3
TdB
Italy
TdB is offline
Thanks a lot
Andy
Old August 25th, 2006, 05:53 PM   #4
Peter Nachtwey
United States
Peter Nachtwey is offline
Peter Nachtwey's Avatar
Some assembly required
Google "Parks Miller Randon Number". This will be easy to implement on a S7.
Code:
int intrnd (int& seed) // 1<=seed<=m
#if LONG_MAX > (16807*2147483647)
int const a    = 16807;      //ie 7**5
int const m    = 2147483647; //ie 2**31-1
	seed = (long(seed * a))%m;
	return seed;
#else
double const a    = 16807;      //ie 7**5
double const m    = 2147483647; //ie 2**31-1
	double temp = seed * a;
	seed = (int) (temp - m * floor ( temp / m ));
	return seed;
#endif
Old August 26th, 2006, 02:18 AM   #5
SimonGoldsworthy
United Kingdom
SimonGoldsworthy is offline
SimonGoldsworthy's Avatar
What do you need the random number generator for ?
Old August 26th, 2006, 04:23 AM   #6
rsdoran
United States
rsdoran is offline
rsdoran's Avatar
Peter, this has been discussed numerous times on this site, are you NOW saying a plc can generate random numbers?
NONE of y'all give me the brand thing.
__________________
http://www.patchn.com Industrial Electrical & Maintenance @ www.patchn.com "Tell me and I forget, show me and I remember, involve me and I understand."
Old August 26th, 2006, 06:49 AM   #7
TdB
Italy
TdB is offline
Quote:
I needed it for some program testing months ago... so i did one which could do the job...
but i'm still curious to know one proper random function (pseudo looking of course)
Tnx for your tips
Andy
Old August 26th, 2006, 10:09 AM   #8
Peter Nachtwey
United States
There are no true random number generators
This algorithm is one in numerical recipes in C and it is really a pseudo random number generator PRNG. It should be obvious that that same seed will generate the same sequence of pseodu random numbers.
Yes, at least pseudo random numbers. The algorithm was always there for anybody to find. There are many others but this is one that is recognized as being a good considering the effort it takes to make it go. Go to www.nr.com and order the book.
Quote:
NONE of y'all give me the brand thing. Today 12:18 AM
I will, why not? Those PLCs that don't support 32 bit INTs or DINTs can't do this. Actually at 32x32 bit multiply and 32 bit divide can be done on a SLC but it would be extremely messy. A S7 can do this easily and efficiently. So?
Old August 11th, 2019, 10:07 AM   #9
xyntec
Netherlands
xyntec is offline
just take values from actual time like ((milliseconds*(minutes+5)/(hrs+3)+17)*3) and convert to a byte, then you have a pretty random number between 0 and 255...
Old August 12th, 2019, 09:14 AM   #10
Firejo
United States
Firejo is offline
Firejo's Avatar
You know this post is 13 years old, right?
__________________
Go Hawks!!!
Old August 12th, 2019, 09:25 AM   #11
xyntec
Netherlands
xyntec is offline
sorry didn't realize, but I myself was looking for a random generator to found out my plc couldn't, so I made something else, but while searching I came to this site and thought I'd share .... :-(
Old August 12th, 2019, 03:28 PM   #12
paraffin power
England
paraffin power is offline
paraffin power's Avatar
Quote:
Random numbers have changed since then
__________________
Whatever hits the fan will not be evenly distributed.
Old August 13th, 2019, 01:32 AM   #13
Ronnie Sullivan
United Kingdom
Ronnie Sullivan is offline
Quote:
Because of Brexit...?
__________________
I promise to get it right 3rd time every time.
Old August 13th, 2019, 06:16 AM   #14
geniusintraining
United States
Quote:
No, I think lack thereof
__________________
Old August 13th, 2019, 01:12 PM   #15
Aabeck
United States
Aabeck is offline
Aabeck's Avatar
Any way of the forum auto-locking a thread after x years? Or months?
__________________
Never underestimate the quality of idiots that will be running your machines
http://aabeck.com
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Random number generator for PLC5 Contr_Conn LIVE PLC Questions And Answers 12 December 27th, 2019 07:07 AM
S7 Random Number Generator RRobbins LIVE PLC Questions And Answers 14 July 8th, 2016 07:36 AM
Usless but maybe fun excercise ndzied1 LIVE PLC Questions And Answers 6 May 15th, 2006 06:28 AM
PLC 5/04 random number generator seat14 LIVE PLC Questions And Answers 2 December 10th, 2005 11:29 PM
Random number Shahed LIVE PLC Questions And Answers 4 December 3rd, 2005 03:25 AM
