wesselvos
Hello,
In my installation im trying to run a Powerflex 753. I however am having a little trouble running it at the right speed from the PLC.
I looked up the manual which describes using the reference command for speed. I have checked parameters 300, 37 & 520. These are set to Hz and both 60 Hz respectively.
However when I for example enter 30 in the reference tag, it will run at a very low speed with the run command. I expected it to run at 30 Hz like the manual describes. The feedback will show 0.05 and the output freq will show 0.
After using the jog command it will run at 10 Hz, the feedback and output freq will show this. I'm not sure where the jog speed is coming from tho, probably one of the parameters.
Is there something im overlooking or doing wrong? I have attached pictures to show what im talking about.
Thank you!
Thank you!
