what difference between Continuous updating and Mass I/O copying?
steven37
Jun 2006
sp
what difference between Continuous updating and Mass I/O copying of PLC's oprational characteristic? can anyone tell me?if can in table form to make it more clear, thank..:)
Could you give us a little more information about what you are looking for? I can't speak for everyone, but I'm afraid I don't understand your question.
"Continuous Updating" to me refers to an asynchronous I/O scan.
"Mass I/O Updating" refers to a synchronous I/O scan.
Okay, so what does that mean?
Synchronous I/O updates means that the I/O is scanned (or maybe just the I), then the user program is run, using that 'Copy' of the physical I/O. In the case of seperate I's and O's, the outputs are only 'physically' updated at the end of the user program scan.
With Asynchronous I/O, the I/O is scanned, and updated either immediately, or at the next timeslot for the update, irregardless of the state of the user-program. With Asynchronous systems, you might see input x.y true at the beginning of the user-program scan, but false somewhere else in the user-program scan.
i want to know the difference between a continuous stall torque and rated torque and Standstill torque because i need to remplace a servomotor...
2,157
Hello, I have a problem with AO- and AA-Tags. When I use for example the tag AO_Test with the address 200 and type the value 1,2 in, the AA-Tag...
1,407
As per the title. This might seem like a basic question to many, but I'm unclear about the difference between a coil ( ) and an application...
28
4,015
Good Morning , I have 2 Frequency Drive panels to build and commission . It is for 2 pump systems . Just wondering , what is the...
1,963
Hi Experts, Good day! What are the differences between PCS7 SIMATIC Batch and PM Control? Do you have any manual like "Getting Started "...
807
