Justwalk123
I am using FactoryTalk VIEW alarm server to set level alarms on tags in the PLC. I am pointing the Enable and Disable bits for the alarms to bits in the PLC so that the PLC can enable and disable the alarm based on conditions, and pointing the Disabled status bit for the alarm to a bit in the PLC for feedback. Sometimes this works. Sometimes not. It seems like the connection between the alarm server and PLC gets broken. I can go into the alarm server, edit a single alarm and reselect a single control bit, save the edit, and it fixes the alarm I just edited plus all the other alarms. It’s like I poke the alarm server in one tiny spot and it resets and fixes the connection. Until some random time when the connection goes south again. Has anybody else seen this, and most importantly, fixed it permanently? I’m using FTV SE 10. Thanks in advance.
