Siemens Counting module
roxtech
Mar 2008
Township Lahore
198
In manual there is no detail about availability of function latch/retrigger. but when i try to parameter for this function. I did not find parameter related this. then i search in help file and found this function is only available in module 6ES7 350-1AH02-0AE0.
Please check the help file of function module package CD. Click on Latch/Retrigger
Best Regards.
Best Regards.
module 6ES7 350-1AH03-0AE0 have no latch/re trigger function.
some thing missing above.
Hello Zahid,
It has been a while, but I seem to remember those FM counters have a hardware gate, to enable/disable counting. Is that what you are looking for?
Been scratching my head at what I thought should be a relatively simple task. I need to count how many rows a .csv file has, so I can later read...
2,540
19
90
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
281
i have two plc 1. s7-1212dc/dc/dc ip; 192.168.0.1 2. s7-1500 1513-1pn ip; 192.168.3.2 i need to get data from plc1 to plc2. any idea how to do...
97
