Smallest cameras to use in machinery with DVR
Cydog
Feb 2018
Maryland
313
Good Afternoon,
We have some new machinery and we are going to be
networking the entire plant in 2019. Do you guys know of any
small cameras / DVR's that are fairly small . I have gotten same
Night Owl cameras from Best Buy , but I'm looking for something
smaller .
Thanks in advance ,
What is the size constraint? What is objective for said camera; Is it for quality control, quantity count, or micro-managing slackers?
My bet is on incident investigation.
The only time I needed a spy camera like this was to find out who was fiddling with the comms cabinet... Funny thing, it turned out it was done remotely by the company that provided the service without any notification to us.
I would however look up legislation concerning recording devices in work environments... particularly of the concealed type before deploying something like that.
It is for recording jam ups , so we can play back in frames to see the cause , and also use for training .
I suggest a Pelco IXE series box camera so you can match whatever focal length / field of view lens you need. That camera will do 60 FPS in HD resolution. You can get a copy of DS4U NVR software for free. Use a dedicated PC as your NVR platform. This is probably the smallest camera Pelco has. You haven't provided any information on the size requirement.
Shawn
Hello friends. There is an int type, number that I got from the DataBlock. For example, the DataBlock address is Db1.dbw0. Here's what I want to...
32
10,435
I have a full 13-slot SLC5/03 rack and need to add one or 2(max) 16 point 120v AC input cards. What is the most compact, least expensive way to...
2,147
I just ordered a TECO brand Smart Relay or micro PLC for a very small project in which space is at a premium. The application calls for logic...
5,430
some of the existing ethernet IO modules having problems after adding couple camera(Keyence IV3).Tried swapping the switch with a bigger one...
1,637
I am looking for information on camera systems for monitoring machine lines. Does anyone have any suggestions? I have done this in the past using...
1,873
