Fanuc TP Programs to be able to view in Notepad
Rob S.
Sep 2008
Maryland
739
Good Evening ,
It has been awhile since I did anything with Fanuc TP programs.
I know there is a way to view them in Notepad. What do you need to
to convert them to be able to view them in Notepad ?
Thanks so much in advance .
If they are on Ethernet then use the FTP command in the command prompt. I use a commands.txt file that has the switches I want to use when I run my batch file.
For example
commands.txt has the following in it:
anon
prompt
lcd ROBOT_BACKUP
mget *.*
quit
Then I run a batch file with this line in it:
ftp -s:commands.txt XXX.XXX.XXX.XXX
Replace the "X"s with the IP address of the robot.
Make sure the batch file, commands.txt and a folder called ROBOT_BACKUP are all in the same folder. Then run the batch file.
Since I am not using the "bin" switch, the LS files will show up in ASCII instead of binary. add the "bin" switch if you want a binary backup.
Any other questions just ask.
@mobsoft, thanks for that nugget. I dont remember that from class.
Does ftp need any enable for this?
Is there a doc for supported batch commands?
@OP: You should be able to backup the TP programs to a usb stick -- if supported.
When you select backup menu, backup TP programs, select (.LS) file format. You will have to do this individually from the all the above backup i believe
We have numerous OEM GE Fanuc 90-30 processors that have lost their programs during extended power outages. I'm not that familiar with the Fanuc...
3,036
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
108
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
110
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
102
We recently purchased a IC693CPU352 module and it appears the internal time clock is static. I can set the time and date but once set it does not...
170
