Can you edit a Rockwell FactoryTalk hmi file with Factory Talk SE
passwordg
Aug 2011
South Carolina
224
We have a FactoryTalk HMI running on an industrial PC. Which software do you need to edit and add screens to this ?
I'm confused with Factory Talk SE and ME.
What I read was FactoryTalk View Studio SE can edit both SE and ME projects. FactoryTalk View Studio ME can edit ME projects only.
So should I get the SE license to cover all bases ?
FactoryTalk View ME can run on a desktop PC as well as on the PV+, so it would be best to find out from the customer what edition of the software they have. A look at the Start menu might do the trick, or at the Activations that are installed.
If FactoryTalk View ME Station is installed, you'll see it in the Start menu under Rockwell Software -> FactoryTalk View -> FactoryTalk View ME Station.
If you had to go in blind, you need to buy FTView Studio SE edition in order to have the ability to edit both SE and ME projects. Unless there is a very good commercial reason to go in blind, I don't recommend it.
Hello! I am working with a project that uses lots of Parameter files to pass information between screens. When I open the parameter file in...
1,871
Hi all, Over the past few months, we have been experiencing an issue with our PCs that I wanted to reach out and see if anyone else had...
8,099
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
125
Searching edit zones within all routines and other criteria still says no results found, yet I still have the "edits present" indicator at the...
249
Does anyone know where I can get TouchWin Edit software version V2.C.5 or above? Xinje's website is lacking. I just got a newer TH765-N display...
163
