What would you use a multiturn incremental encoder for?
jagjag1
Jan 2012
Codesys
17
Hi everyone.
We buy servo motors and there are 2 options of encoders.
Incremental SinCos hiperface singleturn encoders and
Incremental SinCos hiperface multiturn encoders. I understand the benefits of the multiturn absolute encoder but for what would you use the incremental multiturn encoder for?
Thank you
Multiturn encoders are commonly used on CNC machine beds for positioning, or anywhere really you need an absolute position signal greater than one revolution of the encoder shaft. Many electronic multi-turn encoders do hold their position through power cycles, but not all. Mechanical multi-turn encoders can also correctly report position, even if they have been moved with the power off.
From Dynapar
In the past, I've used them to monitor position on some 600 foot accumulators we have, but went back there to single turn encoders, and handle the count in the PLC.
The encoder type you are referring to actually has two outputs and is truly both an incremental and absolute encoder at the same time. The first output is the SIN/COS output, which will take up four wires and will produce the SIN/COS cycles at whatever the counts/revolution value indicated on the encoder. This track is often used for very high bandwidth, high resolution incremental position determination but it is only absolute within one count cycle. The position value is interpolated between SIN/COS cycles by examining the relationship of the sine and cosine tracks.
Both the single turn and multiturn variants of the encoder are also absolute encoders. It is just that the multiturn keeps track of absolute position over multiple turns. The absolute position information is transferred over Hiperface, which is one of the high speed serial links, in this case developed by Sick, I believe. The base Hiperface has been around for quite a while. Incidentally, the latest version of Hiperface, Hiperface DSL, is now fast enough that the dedicated SIN/COS channels are generally not required.
Keith
G
I`m planing to maybe use this Multiturn absolute encoder. http://www.pepperl-fuchs.no/norway/no/classid_363.htm?view=productdetails&prodid=50626...
1,905
gordon
G
Hi all, I am using a B&R X20 unit and want to integrate an incremental encoder (OUT A, B, & Z). I have three BOOL digital input pins for my A,B...
395
I have a question regarding the features of the so called incremental (velocity) form of the PID controller. As far as I understand this form in...
2,378
Hi, I have some Baldor (Baldor is now ABB) servo motors that have revolvers for position output. But to my surprise the Baldor MicroFlex...
3,707
A bit of background here: We use an incremental encoder with a counting module in our PLC configuration. Using dual phase / quadrature counting...
26
8,771
