16 port router recommendations
KingPresident
Aug 2015
Michigan
138
I'm finding failures in the Skorpion-16 eisk16-100t. Last month I experienced a non failure - failure. It would not let me ping or connect to anything connected to it, yet the PLC, HMI, ect worked as it should.
This morning in another system, a unit simply failed.
I'm asking for 16 port unmanaged switch recommendations. We have Hirschmann security routers for plant connection, and behind Skorpions in the LAN
Funny I was just researching them yesterday... I have a couple that are giving me issues and im having to reboot them
I do like Hirschmann but I was looking at AD's yesterday,
https://www.automationdirect.com/ad...ations/Industrial_Ethernet_Switches/Unmanaged
I was looking at 10 port but they have a 18
EDIT: they also have a 16 https://www.automationdirect.com/ad...ernet_Switches/Unmanaged/10-z-100/SE2-SW16U-T
Edit2: I was also looking at Cisco https://www.cisco.com/c/en/us/products/switches/industrial-ethernet-switches/index.html
We use AB Stratix 2000 or Weidmuller for our unmanaged switches. Never had a failure.
Seems like the Weidmuller are only available in 5 or 8-port though.
AB Stratix 2000 16-port
1783-US16T
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
64
Very similar issue as the last post I had here with communicating our Linux Gateway to an AB CompactLogix controller. I have assigned a gateway...
162
Does anyone know of an AOI using the user ASCII protocol select on the L6x controllers that will talk Modbus RTU using RS-485? Thanks, Trevor...
117
Dear all, what type of built in port does fx2n-80mr plc has? i mean is it rs232, r rs422 or rs485. and which module should i use to convert to...
98
I have a piece of equipment that is operated by a PanelView Plus 600 HMI touch screen via RS232 into a Micrologix 1500 PLC. I am trying to...
141
