plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old February 28th, 2023, 10:17 AM   #16
plvlce
United States
plvlce is offline
Quote:
Originally Posted by dmroeder View Post
V13 removes the ability to make 5.1 and lower runtimes again, this time, it won't be patched.
This technote seems to suggest it already has been patched, contrary to their initial statements that it would not be. Haven't tested it myself as I'm still using v11.
Old February 28th, 2023, 10:42 AM   #17
dmroeder
United States
dmroeder is offline
dmroeder's Avatar
Quote:
Jeez, I did the same thing with V12. Made a statement, someone posted "that has been patched". V12 software still warns you when you make the runtime "This is the last version that will be able to make v5 runtimes".
I spoke with support about this a while back. They confirmed, nope, v13 won't be patched. So here I am again, turns out, it has been patched.
__________________
Open source python communications library for CompactLogix/ControlLogix/Micro800 PLC's:
https://github.com/dmroeder/pylogix
Old February 28th, 2023, 10:58 AM   #18
plvlce
United States
plvlce is offline
Jeez, I did the same thing with V12. Made a statement, someone posted "that has been patched"..
Déjà vu all over again.
Old February 28th, 2023, 11:05 AM   #19
dmroeder
United States
dmroeder is offline
dmroeder's Avatar
LMAO, I was thinking it was you that corrected me. Thanks for keeping me honest.
__________________
Old February 28th, 2023, 11:15 AM   #20
plvlce
United States
plvlce is offline
We'll see if it happens again with v14 in another 10 months
I doubt it. At some point they're actually going to carry through with dropping support and my bet is on sooner rather than later.
Old February 28th, 2023, 01:50 PM   #21
arpus4KM
United States
arpus4KM is offline
well, when that support drops we are going to see a huge gap again where if 14 drops support. then a lot of HMI will either be V13 or V17 after a sufficiently long time has passed where people end up being forced to upgrade to support new machines that have been put out.
Old March 3rd, 2023, 10:32 PM   #22
Tmiller2
United States
Tmiller2 is offline
Tmiller2's Avatar
I just wanted to follow up with this thread. We were able to load an application for FT View ME ver. 11 on a PVP7 Pro 1200W series B running Ver. 12. The application would not load. It turns out the new panelview must be connected to a network for the RS Linx server in the background to run. This is different. We just plugged in an ethernet cord to the plant network. The older Panelviews did not need to be connected to a network to load and run an application.
Old March 4th, 2023, 10:46 AM   #23
arpus4KM
United States
arpus4KM is offline
Quote:
yeah this is a new and annoying 'feature'. the ethernet port isn't even configurable unless it's connected to a valid network. New PVP aren't even coming loaded with the newest firmware and require updates as soon as we have been getting them also.
Old April 13th, 2023, 03:19 PM   #24
gjansen@keithsfoods
Australia
gjansen@keithsfoods is offline
Hi
I am new to this forum and cant find the POST NEW button.
I am looking for a copy of FTV ME 6. We have a old XP laptop with V3.2 on it. I am working on a Micrologix 1400 PLC project, but V3.2 does not recognise the 1100/1400 PLC's
Rockwell stopped downloads for old versions.
Old April 13th, 2023, 03:24 PM   #25
dmroeder
United States
dmroeder is offline
dmroeder's Avatar
Welcome!
For future, see the attached picture.
The best way to get the software if it is not available for download directly would be to contact your distributor. They can probably get it for you.
__________________
Old May 25th, 2023, 11:52 PM   #26
wang hengfa
China
wang hengfa is offline
Quote:
Originally Posted by janner_10 View Post
Still one of the very worst HMI software you can buy right now.
I strongly agree with this viewpoint
Old May 26th, 2023, 12:15 AM   #27
thehoneybadger
Australia
thehoneybadger is offline
Hey All. While we are on the subject of PVP and versions. I have a question.
I am running FTView V11. I have a PVP1000 (not PVP6, nor PVP7. Just PVP1000).
I bought it on ebay with Firmware Version 5.10.06. Other versions are available to downloade up to 5.10.16.
I recently updated the firmware to 5.10.16 and caused myself a world of pain. I eventually got it back to original firmware.
Does anyone know the "safe" version i can reliably install in this PVP for use with my version of FTView11?
Old May 30th, 2023, 11:51 PM   #28
RedSoxFan3
United States
RedSoxFan3 is offline
The main benefit to V13 was the change in price point. The grid objects and Powershell scripting also got a little better.
Personally I have not used the .NET objects at all.
Old May 31st, 2023, 12:37 AM   #29
thehoneybadger
Australia
Quote:
Thank you
Old May 31st, 2023, 01:00 AM   #30
RedSoxFan3
United States
Quote:
Originally Posted by thehoneybadger View Post
Thank you
FTView SE is prob half the price it was previously. An unlimited screen perpetual license, panel pc, and 42" 4k monitor is a whole lot less than a PanelView considering you can run dozens of machines from a control room with a multi-monitor setup. A 15" PV+7 Performance is around ~7.6k. An unlimited display perpetual license is just under 4.0k. I don't spec PanelViews anymore though I am end user.
The Network Distributed bundles are half the price and no longer require two licenses to run a redundant configuration and come with unlimited Viewpoint seats for free.
I haven't spec'd out a full Ignition SCADA/HMI package, but from what I can see the pricing is similar. However, for a very large system, I would totally go with Ignition as you have a cleaner transition to MES and cross platforms.
I don't remember what ME got for upgrades as I primarily use SE, but you can check the release notes.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
FT View Studio Old Version eight_bools LIVE PLC Questions And Answers 9 September 9th, 2021 04:56 PM
FT View Studio 7 Issue with RSLinxNG mfoxips LIVE PLC Questions And Answers 4 May 3rd, 2016 11:35 AM
FT View Studio "networks and devices" not populating MomentaryPushButton LIVE PLC Questions And Answers 1 March 16th, 2016 07:02 PM
FT View Studio ME lenzepplin LIVE PLC Questions And Answers 4 September 16th, 2015 07:01 PM
HELP with RSLinx Enterprise and FT View Studio v6.10 kandymann LIVE PLC Questions And Answers 20 December 20th, 2011 10:03 AM
