plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old May 25th, 2023, 02:05 PM   #1
kdcui
United States
kdcui is offline
M12 Ethernet in Class 1 Div. 2 / ATEX Zone 2
Hi -
I am searching for an M12 panel receptacles to use for ethernet connections. I see lots of M12 cables that are ATEX / C1D2 rated but nothing in the way of M12 receptables (I do see plenty of RJ45).
I have concerns with RJ45 durability in a harsh environment (such as RJ45 connectors snapping). I've pretty much used M12 exclusively in cleanroom environments but not in hazardous areas.
Does anyone have experience with M12 in hazardous areas? Alternatively, does anyone have positive experience with "ruggedized" RJ45?
Old May 26th, 2023, 08:21 PM   #2
James Mcquade
United States
James Mcquade is offline
i looked at the Balluff brand we use and they do not list it for hazardous locations. the biggest hurdle i see is that the cable is rated for 4 amps.
what are you communicating with via the cable?
i am familiar with the rules in your situation. i was in the munitions industry for 8 years. there are a lot of unknowns right now.
james
Old May 27th, 2023, 02:17 PM   #3
JeffKiper
United States
JeffKiper is offline
JeffKiper's Avatar
Is the terminals in a C1D2 area or does the cable break the boundaries? Without a lot of details its impossible to help you out.
What Ethernet are you talking about? EthernetI/P , Profi, Ethercat, etc etc. I wouldn't be concerned at all about the RJ45 unless you plan on abusing them. You can see RJ45 on the side of so many industrial robots and devices. If you are putting it in harms way, you need to design the failure mode out of the installation.
We have build several protective shield because the customer was concerned.
__________________
There should be a minimum IQ before people can breed.
FS Eng (TÜV Rheinland, #11004/15, Machinery)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
New PC, Dual Ethernet Port Access to Rslinx SNK LIVE PLC Questions And Answers 2 February 4th, 2009 08:24 PM
Class I Div 2 panel sapoleon LIVE PLC Questions And Answers 4 January 18th, 2007 09:39 AM
Which network should I use? kra101 LIVE PLC Questions And Answers 14 November 15th, 2006 12:28 AM
Using a RADES9300 and serial ethernet to connect to plc...Works over eth but not dial bdoub1eu LIVE PLC Questions And Answers 5 July 28th, 2006 09:30 PM
RFID for Class 1 Div 2 Hazardous Location maverick33 LIVE PLC Questions And Answers 17 March 25th, 2006 09:57 AM
