plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old May 25th, 2023, 11:04 AM   #1
lunenburger
Canada
lunenburger is offline
lunenburger's Avatar
Does Siemens have a product like FactoryTalk View SE?
I am new to Siemens, and just looking into their HMI software.
Does Siemens have a product similar to FactoryTalk View SE?
I am looking to have at least 10 HMI clients and two fully redundant HMI servers.
I have also developed some standalone projects with Indusoft (Aveva Edge) and just wondering if anyone has experience with a larger plant wide installation with Indusoft? how scaleable is it?
Thank you
Old May 25th, 2023, 11:09 AM   #2
widelto
Colombia
widelto is offline
widelto's Avatar
Take a look at Ignition :
https://inductiveautomation.com/scada-software/
It is customizable, and web based.
__________________
My two cents.
Old May 25th, 2023, 11:17 AM   #3
joseph_e2
United States
joseph_e2 is offline
They at least used to have a standalone version of WinCC that would run on a PC instead of an HMI. You would use "WinCC Flexible" to program HMIs. I suspect that they continued that distinction in Portal, but it's been a while since I had access to Portal.
Old May 25th, 2023, 11:27 AM   #4
Ken Moore
United States
Ken Moore is offline
Ken Moore's Avatar
Siemens PCS7 supports multiple redundant servers, and multiple OS clients. I have worked on systems with three server pairs, and over 25 clients.
I am sure the Step7/TIA portal side of things also supports this as well. Contact your local Siemens office for more detailed information.
__________________
Certified Siemens Functional Safety Professional,
NRA Benefactor
Old May 25th, 2023, 12:41 PM   #5
cardosocea
United Kingdom
cardosocea is offline
WinCC is the product you're looking for. Ken Moore mentions PCS7 which is a DCS implementation and uses WinCC as the SCADA bit.
Old May 25th, 2023, 12:48 PM   #6
lunenburger
Canada
I have just downloaded Ignition, and I am going to check out the trial.
I also have WinCC but it looks like you have to run WinCC on Siemens HMI hardware, not deployed on Windows computers??
Old May 25th, 2023, 01:16 PM   #7
joseph_e2
United States
WinCC is deployed on PCs. WinCC Flexible is for HMIs.
Old May 25th, 2023, 01:44 PM   #8
Ken Moore
United States
Ken Moore's Avatar
You can deploy WinCC on standard PC's. However, when you need tech support, Siemens will often blame the non-Siemens hardware.
__________________
NRA Benefactor
Old May 25th, 2023, 01:45 PM   #9
lunenburger
Canada
Sounds like Rockwell...
Old May 25th, 2023, 01:48 PM   #10
lunenburger
Canada
So WinCC can do redundant servers? that is interesting...
I will have to do some digging, coming from a Rockwell background, it seems like it is hard to find information on the Siemens website.
( I suppose it's hard to find information on the Rockwell website if you are coming from a Siemens background as well)
Old May 25th, 2023, 04:58 PM   #11
mk42
United States
mk42 is offline
WinCC is basically the brand name for HMIs from Siemens. It comes in several flavors depending on what you're looking for. What you want is WinCC V7/V8, which is a SCADA class system installed on whatever PC and includes support for redundant servers.
WinCC Flexible is a legacy panel/single station PC system. WinCC Comfort/Advanced inside TIA portal is a newer version of that (but still 10+ years old and near the end of it's lifecycle). WinCC Unified is their new platform that covers the simple embedded panel all the way up to client/server SCADA setups, but it doesn't support redundancy (yet?).
Old May 25th, 2023, 04:59 PM   #12
PreLC
United States
PreLC is offline
PreLC's Avatar
WinCC Professional is what I would compare to be the closest to a SCADA system.
__________________
Ask not what your PLC can do for you, ask what you can do for your PLC.
Old May 25th, 2023, 05:14 PM   #13
lunenburger
Canada
Thanks so much for the info... that's exactly what I was looking for
I couldn't figure that out on the Siemens website... too much information
Old May 25th, 2023, 06:02 PM   #14
PreLC
United States
PreLC is offline
PreLC's Avatar
Yeah makes sense, this page should be enough if you want a Siemens option:
https://new.siemens.com/global/en/pr...sional-rt.html
__________________
Old May 26th, 2023, 05:04 PM   #15
Thomas_v2
Germany
Thomas_v2 is offline
Quote:
I would choose the WinCC 7.x line (WinCC Scada). I have the feeling that WinCC Professional has no future. I've had one project with WinCC Prof. and made so many support requests with bugs, no one fixed since today. The runtime WinCC Prof. uses is a WinCC 7.x runtime, but the engineering has so many missing features compared to WinCC Scada. For example basic process control - missing. You spend weeks to build what comes with basic process control in WinCC Prof., and you can't do all the features because some things are still missing which you can't emulate (group displays).
Also not all combinations from WinCC Scada are supported in WinCC Prof., like Multiclients which connect to multiple redundant server pairs, separate archive servers and so on.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
For FactoryTalk View SE Station single workstation vs distributed AutomatisationBSL LIVE PLC Questions And Answers 4 April 6th, 2022 04:07 AM
FactoryTalk View Studio SE clarification 40mpg LIVE PLC Questions And Answers 1 March 23rd, 2022 04:31 PM
FT View SE Editing Without License Mark Cole LIVE PLC Questions And Answers 9 November 22nd, 2014 09:03 AM
Running FactoryTalk View SE V5.0 to work with FactoryTalk Service Platform 2.40 ? alpine LIVE PLC Questions And Answers 15 December 15th, 2011 07:49 PM
FactoryTalk View Studio 6.1 SE Network Project, Display Component not Found Issue tatsumasa LIVE PLC Questions And Answers 3 September 2nd, 2011 06:54 PM
