SDN showing up as Modbus
LoganB
Apr 2017
Michigan
607
This isn't a problem for me anymore, as today I came in and was able to browse to the SDN card without issue. But yesterday, while attempting to upload a DeviceNet config file through the network, one of our machines was showing me in Linx that it had a Modbus card in slot 1, when I knew it was an SDN.
This morning it was back to showing an SDN. I went offline and rescanned the network a few times yesterday and it kept giving me the modbus card. Pretty weird right?
Yeah, that's definitely weird.
What controller platform ? Do you have any Modbus modules in this or similar systems ?
Does the RSLinx browse literally say "Modbus" or does it give a Prosoft or other vendor part number ?
What version of RSLinx Classic are you running ?
Ken, the controller is a 1769-L32E r19.011, and there *is* a 1769-SM2 in slot 2 as well as a 1769-SDN in slot 1.
LINX version is 3.80
The first time I browsed to it, it showed me the SM2 in slot 1 without the SDN card at all, but because I was just doing an SDN audit on a bunch of lines I'm not yet fully familiar with, I just figured the documentation was wrong and made a note of it. It wasn't until I was informed by my boss that there WAS an SDN on that line and went out to the line with my laptop to hook up locally that I saw the SDN on LINX and realized how weird this whole thing is.
I'm told this line has had really quirky comms problems since it's inception. It's also been known to have all its IO comms just freeze up if someone simply browses to it in LINX at the wrong time. Literally all you have to do is drill down into the IO and it will get so tied up that you need to power cycle the PLC to get it to start working again.
But it's an automotive plant with lots of fires to put out all day every day and not enough firemen, so the mentality up until this point has been "just don't touch it and it will keep working" haha. I just hired into the building to add some much needed assistance on the programming front, so hopefully we will be able to start dealing with intermittent problems like this in the near future.
Hello, I'm trying to replace a 1769-SDN devicenet scanner on a compactlogix system. The issue i'm having is when i replace the scanner and...
1,874
We are in the process of upgrading a controls system. The existing system is a SLC500 with some IO cards and a 1747-SDN module communicating to a...
525
Hello, I am setting up for practice and I am having trouble seeing the 1771 Scanner in RsLinx as well as Rsnetworx My setup: slot 0 : PLC-5/40E...
961
All Found myself in a situation where I need to flash the 1769_sdn Devicenet module from 2.002 to 4.004. I uploaded from the module but it has...
2,356
One of our running machine's DeviceNet Module (1747-SDN) had malfunctioned. So, we replaced it with a new one from spares. We maintained the...
3,015
