Data tables stored external to plc?
02js4130
Jun 2014
Wales
38
i have a project where a simple step by step program has been created for a batching process eg.a recipie is selected and then an ingredient is displayed on HMI and the weight ect, the operator the weighs the ingredient and once completed it roll over to the next ingredient, and then loggs the data on PC via OPCand It works fine. i now need to create one for many more recipies. Currently i am using a mIicrologix 1500.
I have bought a ML1400 and we were considering connecting the using DH485 and one plc hold the recipies and ingredients data
while the ML1500 will hold the basic data from scale ,storing barcodes ect.
I have researched that the communication is done using the MSG function but need to understand more about it,first.
As an alternative i was wondering if it is possible to have a PC connected using maybe OPC and the PLC talks to to the PC and aquires its recipe data from it maybe from Excel or SQL, if a data table was created. is this possible at all ?
ThaNks in advance
Store your recipes in a SQL database, SQLExpress works fine for that, Then use an HMI application to handle selecting a recipe and moving it to the PLC. I'm sure you could use AdvancedHMI for this, with a little bit of work, and for free.
Ignition as an HMI would make this an absolute breeze, but is more expensive.
You could probably also use something like a Red Lion HMI, or DataStationPlus.
Hi All, I need a step-by-step method to insert and update lines in the database SQL Server via software builded in FT View SE. Thanks. Fabricio
60
18,634
I have very annoying and potentially dangerous problem with S7-1500 PLCs and TIA Portal. Whenever I add a tag to a data block or even change a...
19
15,177
Hello I was wondering if someone could give me a good explanation on Data Tables? Im working in a SLC 500 program and haven't really used it much...
3,073
We currently have an RSEnergyMetrix server in place that allows us to pull data from all of our PowerMonitor 3000s. We would like to pull this...
1,657
I am curious to how the Fanuc CNC can update a Data Table in the PMC. I have figured out how the PMC writes the data to the CNC and I have found...
4,380
