Distance between Ethernet cable from power cable
Tracteur
Jul 2010
Quebec
17
hi guys, I want to know what's are the distance to respect to have no problem with the communication cable.
I've 600V, 400A teck cable i have to follow the same path with an ethernet cable in teck shielded.
So what will it be a safe distance between those cables.
Thks
Check IEEE C2-2007 - National Electrical Safety Code (NESC). I think minimum distance is around 0.6 m, but I'm not really sure.
Dear, i am need to know what is the optimum distance between the control ducts (24VDC) and electrical ducts(400VAC) for example, burried in...
1,692
Hi there, I am currently working on a project where we are upgrading a number of SLC PLCs from DH+ to Ethernet, and was wondering if anyone new if...
2,490
Hi, Can anyone please confirm this. I remember i read somewhere sometime ago that the distance between each node in the DH+ network must have a...
4,094
Hello everyone, What's the difference between nominal sensing distance and maximum sensing distance in a diffuse photoelectric sensor ? in...
1,120
Hi all, I have an Allen Bradley PLC which is connected to a Kinetix 300 drive. I have been using MotionView to adjust the different positions...
1,269
