L18ERM IP adress keeps resetting
dwoodlock
Nov 2012
Cincy/nKY
567
I am working with this controller and a servo drive on an application. I keep having this strange issue where when I power cycle it, I will have to use the BOOTDHCP utility to reassign the IP address. The logic seems to stay, but the IP address does not.
Anyone able to give me some tips or pointers with this PITA?
Thank ya
update:
I figured it out, had to change the configuration in RSLINX to "Manually set" instead of either of the 2 automatic options. Wasn't aware this configuration had to be done in linx, my mind has become too "siemens'ized" at this point I guess.
Raise your hand if you've forgotten to disable BOOTP/DHCP !
See ? Everybody does it.
It's been part of my commissioning checklist for years, and *still* I forget sometimes.
Let me tell you all about the IP configuration data assembly overwrite feature in Festo CPX terminals sometime....
I have the exact same issue as the OP in this thread. https://www.plctalk.com/qanda/showthread.php?p=916010 I swapped parts with another L18...
2,828
Hi, I have a compact logix processor with embedded IO but the IO is not responding nor flashing on the self test when boots up. The IO light is...
3,620
Hello, I am a bit familiar with PLC programming, but I've never dealt with servo drives before. I am having a hard time even establishing a comm...
1,368
I am using studio 5000 v24 software for controlling a servo drive. Kinetix 5500 and using the 1769-L18ERM processor. The module I created the...
4,289
I am having trouble reading the status of a printer I have attached to my 1769-L18ERM-BB1B PLC. I can transmit Data correctly but not receive the...
2,163
