RSView32 & VBA
aiki202
Aug 2007
Pennsylvania
178
How do you close the current RSView application with VBA code? I have tried using a button on a screen that calls a VBA subroutine. Within the subroutine I have:
gCommand.Execute ("Quit")
This doesn't work.
Also, does anyone know how to shutdown a PC running Windows XP SP2 with VBA code in RSView32? I found 1 example on the internet but it also does not work.
Thanks!
tomalbright said:
I have a button that exits RSView, it has the code:
DisplayServerOff;Pause 4;Quit
Works every time.
If I place the "Quit" command behind a button in RSView32 it also works properly, but it will not work from the VBA code?
danpantea said:
There is a a call of another program in both RSView and VB. I used it before from PCIM (VB based SCADA) and than for some customers I used it from RSView. You might get static from Windows if you are not in REAL ADMINISTRATOR login.
I was looking for actual VBA code to perform this task. Something like a Windows API call?
I figured out both issues. The "Quit" command was not working from the VBA code due to the fact that it was in a module. I needed to call the sub in the code module from the project module. Shutting down Windows XP (XP only) is done with a 'Shell' statement. The shell statement forces a shutdown. I am sure there is a way to stop each process correctly, just like a normal shutdown does, but I have not figured this out yet.
Good friends, I'm new to the forum, I'm working with RSview32, someone can help me how to make a macro in VBA, to save some data in Excel. to...
1,955
We were given RSView32 project files, for quoting, that will be converted to FTView SE. Unfortunately the project has VBA references that were...
4,323
Hi, I got a RSview32 project from site with VBA scripts and trying to run on my local machine to make some graphical changes. VB scripts are used...
3,498
Please somebody upload this manual on another site or forward me 51770 - Sample VBA: Exercise in migrating an RSView32 application with VBA to...
4,914
Hello all, New to the forums here and glad to find this oasis of RSView/FactoryTalk info! I have a basic VB question I hope can be answered...
2,310
