Uploading a program from a A-B 2711P-K6M20A8 pANELVIEW PLUS 600
ksa858
Jul 2014
Danville
84
I uploaded a program file from a PanelView Plus 600 and that program file has been saved in the Runtime Directory for Factory Talk. When I open up Factory Talk Machine Edition and I want to open that application but it is not listed in the application box.How do I transfer that file from the Runtime Directory to the Machine Edition Application box?
You need to go into the application manager and restore runtime application.
This can only be done if the original programmer has allowed this on download.
If you are asked for a password the chances are it is just blank.
Let us know how you get on.
Cheers
Mark
Well done!
Just a quick note here...
swayne76 said:
...You can restore an .apa file from a .mer file...
Geospark said:
...You do not restore an MER file to an APA file...
...You are attempting to restore an MER file to an MED file and sub-folders...
swayne76,
Just be careful with what is what here.
One is always attempting to restore to an MED (Machine Edition Development) file and sub-folders, whether you have an MER file or an APA file.
One is never restoring an MER file to an APA file, or vice versa.
An APA (APplication Archive) file is just a backup file of the MED file and sub-folders for safe keeping or transfer to another user, etc.
To open and edit an application, one must have an MED file and sub-folders.
So,
The Application Manager can restore either an MER file or an APA file to an MED file and sub-folders.
This was the distinction I was trying to make in that other thread.
Regards,
George
Hi everyone, I want to upload the program from my CPU317TF-2 DP to my PC via connecting to CP 343-1 Advanced since it has LAN ports and the CPU...
167
Hey, i'm getting an error when i try to upload a program from a modicon M258 TM258LF42DT using eithernet. i tried using both SoMachine V4.1 and...
1,314
So i have an allen bradley rack (2080-LC50-24QWB), i have it connected through ethernet. I dont have an offline program so im trying to upload...
676
Hello im hoping someone can point me in the right direction. I have a SLC-500 that the program has been erased. I'm being told it will require an...
1,538
Hi dears I am facing problem during program upload on S7 200 (226 cpu)microwin 4 sp9 closes on 100% I try to upload data blocks, its ok, System...
2,452
