3 way Control Valve from Siemens with Beckhoff PLC
tech007
Aug 2010
London
25
Hello,
I have question regarding the 3 way control valve with magnetic actuator which is MXG461B15-1.5. As i want to use this valve for accurate water temeprature control application for cold and hot water. I would like to control the outlet temperature of the water. I have gone through the documentation of this control valve also.
This valve input and output, i will connect with Beckhoff PLC Terminals respectivaly EL3162 and EL4104.
Now, there are three different ways for controlling through the switch position.
1. Voltage control
2. Current control
3. As per valve characterisitc i.e. Linear and Equal Volumetric %
My question is, how to control from the PLC ? Do i need to change the voltage or current respectively from terminal ? From where i should get feedback of position or position error ?
I have limitation also that i can use only Beckhoff PLC as another system running on Beckhoff PLC.
Can i get example with same terminal from Beckhoff i.e. EL3162 and EL4104 ?
Thanks.
Regards,
tech007
http://www.sps-forum.de/editpost.php?do=editpost&p=324338
Hello Everyone, I have a control valve that needs to be configured and added to existing system. It is connected as per attachment "FCV104". Now...
2,026
Hey Anyone who have managed to construct a motor valve control with Siemens logo and is willing to share? What I mean is software controlling...
4,157
I have been requested to test this proportioning valve for PLC control of flow/pressure. Dwyer Series SVP Proportioning Solenoid Valve The flow...
419
So I'm pretty green when it comes to troubleshooting in the field so bear with me. We have a Danfoss valve that opens/closes from an analog output...
23
953
Hi there, We have a system at a water treatment plant where large raw water tanks feed into the plant that's all on the same level. At high tank...
18
3,760
