Looking to send/recieve real time data between PC - PLC
vha23
Feb 2003
27
Hi, I'm pretty new to plc programming. My current project at work is to design a c++ program that will be able to communicate to an allen bradley SLC 505 plc via ethernet. ultimatly, i'm looking for the pc to recieve data from the plc, use that data to search an sql database, and then return a value from the database back to the plc. Is there any source code or drivers to do the communications? i would prefer freeware, just to see if I would be able to do it. Then I could spend money on a more expensive package if i need to.
Thanks a lot for all your help.
ABEL
Search for Ron Gage's ABEL - Allen Bradley Ethernet Library. It's a Linux-based set of programs for talking AB-ethernet. I have no clue as to how hard it would be to translate that to a Windows C++ platform.
But I'm not aware of any freeware communications drivers, but several companies sell communication drivers, some with downloadable demo versions which will work for a period of time or with limited functionality.
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
126
I have Allen Bradley plcs, I have had Circuit breakers and other automation equipment in the past. There's no solid buyers local. How much do you...
201
can anyone has a good program to learn plc programming online. i have the basic looking into improve my skills thanks
144
I want to monitor a couple signals in a place where there is no PLC but there is ethernet. I know I can use an AENTR or Flex I/O and a module but...
21
767
I downloaded v24 for studio 5000 but can’t find where the download manager put it! Any help? I’ve done it before but can’t remember. Thanks
388
