Using DDE to communicate to RSLinx from Wonderware Application Server
phuz
Jun 2008
Mohnton, PA
1,044
I am building a new galaxy for a customer and I am trying to test things as I go. All my Ethernet PLCs are OK, but I have a test PLC5 in my office that I communicate to via DH+ through a DHRIO module in the CLX chassis.
I set up a DDE topic in RSLinx (Gateway) so it's visible, and on the Wonderware side, I set up a DDESuiteLink client, using DDE, to access the RSLinx on the remote server. Unfortunately, it's not connecting. I tried "RSLinx" "RSLinx OPC Server" "RSLinx Remote OPC Server" for the server names, but none of them work.
Looking from my RSLinx side, I don't even see any connection attempts or anything in the DDE packet logs.
Any ideas?
Looks like DDE isn't supported anymore. I tried OPCClient and the Suitelink client using FSGateway. Getting very similar errors. I changed the DCOM permissions and restarted OPCEnum.
105891 12/12/2017 10:32:51 PM 6080 4656 Warning FSGateway Failed to create OPCEnum on node 'w520ssd'. If you specify server ProgID then FSGateway expects OPCEnum to be installed on the server node.
105892 12/12/2017 10:32:51 PM 6080 4656 Warning FSGateway If you don't have OPCEnum installed, please specify Server CLSID instead of ProgID.
105893 12/12/2017 10:32:51 PM 6080 4656 Warning FSGateway Connection lost or reconnect attempt failed. Retrying attempt 1 of 3 in 30000 ms
105894 12/12/2017 10:33:21 PM 6080 4656 Warning FSGateway Failed to create OPCEnum on node 'w520ssd'. If you specify server ProgID then FSGateway expects OPCEnum to be installed on the server node.
105895 12/12/2017 10:33:21 PM 6080 4656 Warning FSGateway If you don't have OPCEnum installed, please specify Server CLSID instead of ProgID.
105896 12/12/2017 10:33:21 PM 6080 4656 Warning FSGateway Connection lost or reconnect attempt failed. Retrying attempt 2 of 3 in 30000 ms
105897 12/12/2017 10:33:46 PM 6080 2476 Warning FSGateway Initial update from OPC server after activation/creation of item 'C5:7.ACC' in topic 'OPC_DeviceGroup' never occurred, injecting bad quality 18h
105898 12/12/2017 10:33:51 PM 6080 4656 Warning FSGateway Failed to create OPCEnum on node 'w520ssd'. If you specify server ProgID then FSGateway expects OPCEnum to be installed on the server node.
105899 12/12/2017 10:33:51 PM 6080 4656 Warning FSGateway If you don't have OPCEnum installed, please specify Server CLSID instead of ProgID.
105900 12/12/2017 10:33:51 PM 6080 4656 Warning FSGateway Connection lost or reconnect attempt failed. Retrying attempt 3 of 3 in 30000 ms
105901 12/12/2017 10:34:22 PM 6080 4656 Warning FSGateway Failed to create OPCEnum on node 'w520ssd'. If you specify server ProgID then FSGateway expects OPCEnum to be installed on the server node.
105902 12/12/2017 10:34:22 PM 6080 4656 Warning FSGateway If you don't have OPCEnum installed, please specify Server CLSID instead of ProgID.
105903 12/12/2017 10:34:22 PM 6080 4656 Warning FSGateway Reconnect attempt 3 of 3 failed. No more attempts will be made.
Hi Guys, This is my first post so not sure what response I will get. I regularly use Excel to retrieve data from PLC's at work as it is quicker...
2,585
Hey all, This is more of a question of "can I do this more efficiently" rather than how do I do this... We collected a week's work of...
3,343
Hi I recently saw an AB/Rockwell guy using a excel spreadsheet of config data which he could read or write to a plc via opc. Anyone got an example...
6,142
I am new to PLC networks and I'm wondering if anyone can help. We currently have a Micrologix that is controlling a system and I would like to get...
4,626
Greetings everybody, I'm trying to establish a DDE communication between Monitor Pro 7.2 and Excel 2003. I'm configuring Monitor Pro as a DDE...
4,184
