Can RSLogix show me difference b/t project in PLC and laptop?
unsaint32
Oct 2012
minneapolis
365
As a maintenance person, I have my own laptop that has RSLogix 5000 V16.04.00 (CPR 9), and whenever I go online, I save the project before I exit.
If a change had been made by an engineers while I was gone, it'd be useful for me to know what change had been made.
Next time I go online with the saved project (now different than the latest project in the PLC), is there way for me to make the RSLogix show me the difference between my project and the current project?
The PLC is Controllogix 5000 1756-L63
if you followed the default setup when the software was installed, you should have a COMPARE feature listed under the Tools selection on the RSLogix5000 main menu ...
if you didn't install the compare feature, you should be able to install it from the RSLogix5000 DVD ...
basic idea: you tell it that you want a "New" file (which is just a framework for the comparison operation) ... then you browse to each of the two files that you want to compare ... after it grinds away for a few minutes, start hitting the light blue arrow buttons ... this should take you step-by-step through any differences between the two program files ...
rslogix 5000. New instructions show on left of the where i am currently selected. So if I make a new branch then use the toolbar to create a XIO...
2,259
Hi I'm working on a project in structured text in RSLogix 5k. When I verify my program it shows the errors and warnings in the buttom of my...
5,393
I'm using AB's MicroLogix and it suddenly started showing all I/O using bit addressing, while the report options clearly shows word/bit addressing...
3,781
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
80
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
144
