Hi guys,
We've got a small project of converting an SLC 150 (1745-LP153) into MLX 1000 (1761-L32BWA).
Appreciate it if you guys can help me on the wiring and I'm not familiar with it.
The existing ladder program in SLC 150 I managed to get rung-by-rung from a handheld.
Referring to the attachment:
1) The SLC 150 has an output point labelled "11" (Over temperature increase confirm) & "111" (controller normal), from the User Manual, it's written as "Hard contact relay outputs, No arc suppression". This means I can wired them into MLX output point "0" & point "1" ?
2) The SLC 150 outputs "VDC1" & "VDC2" are connected to BCZ24 (N24 VDC), so my MLX 1000 "VAC/VDC" point will be connected to "N24 VDC" as well, right?
3) The SLC 150 output has "COM1" & "COM2", which is connected to "P24", but my MLX 1000 does not has this "COM". What should I do?
4) The SLC 150 input "COM" are connected to "P24", so the MLX 1000 "COM" should be the same, right?
Hope you guys can help me on this, thanks in advance.
