plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 3rd, 2018, 09:13 AM   #1
colemaj1
United States
colemaj1 is offline
FactoryTalk View global object in a global object
Hi, I have been using global objects and appreciate the amount of time they are saving me when developing HMI displays.
Is it possible to have a global object within a global object?
For example, I have a global menu banner that I include on each of my main displays which works fine. But what I'd like to do is have my actual menu items be global objects as well. That way if I change the look of one, it will populate to all.
I tried creating the global menu item, and I've tested it on a regular display fine, but when I drag it to my global menu banner, the menu item doesn't give me an option to define global parameters. The option is grayed out when I right click on it.
Is this permitted and I'm doing something wrong, or are nesting global objects not permitted at all?
I'm on FTV 9.0.
Old January 3rd, 2018, 03:37 PM   #2
arlenjacobs
Canada
arlenjacobs is offline
No, you can't nest global objects.
Only the top level group will be the global object.
When you copy/paste a global object inside the group of another global object, you just get a more complicated single global object.
Just create one global object for your banner and each menu item.
Copy/paste the banner and menu items that you need to each display. A little bit more work now, but from then on any changes to your menus items will populate out to all your displays.
Old January 3rd, 2018, 04:01 PM   #3
colemaj1
United States
colemaj1 is offline
That answers my question. Very good thanks for the help!
Old January 3rd, 2018, 06:01 PM   #4
keshik
Canada
keshik is offline
One quirk to this: you can copy a sub-group of a global object to a display screen and it will operate as its own global object (I understand that this is not what the OP is trying to do). You won't be able to use parameters on this sub-group though.
Old January 3rd, 2018, 07:51 PM   #5
MATT116
United States
MATT116 is offline
You can edit multiple objects at a time using the property panel.
For example if you have 10 buttons right click one button and open the property panel now hold down the control key and select the remaining buttons. Now when you make changes in the property panel it change all buttons. Also you can select the “state”you want to change.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
FactoryTalk View Studio - SE w/PlantPax Setup DarrenG LIVE PLC Questions And Answers 21 June 16th, 2017 12:01 PM
Accessing FactoryTalk View SE object properties on different screens phuz LIVE PLC Questions And Answers 2 June 9th, 2017 01:45 PM
FactoryTalk view SE questions Kalagaraz LIVE PLC Questions And Answers 9 June 1st, 2017 11:47 AM
FactoryTalk View Studio for Machine Edition "Unable to Install" abyvarghes LIVE PLC Questions And Answers 2 March 23rd, 2016 06:31 AM
Passing Global parameters in Factory Talk View Se Tom Kazakoff LIVE PLC Questions And Answers 0 September 1st, 2009 12:34 PM
