plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Unread September 15th, 2019, 10:19 PM   #1
Poykim
Philippines
Poykim is offline
Etap
HI, can someone explain to me what is the purpose, use and function
of ETAP by AB. thank you
Unread September 16th, 2019, 08:39 AM   #2
ivo.maenen
Belgium
ivo.maenen is offline
ivo.maenen's Avatar
https://www.google.com/search?client...d&q=ETAP+by+AB
__________________
Assumptio mater errorum est.
Unread September 16th, 2019, 12:10 PM   #3
dmroeder
United States
dmroeder is offline
dmroeder's Avatar
AB has the concept of a Device Level Ring (DLR), where you can connect Ethernet I/P devices in a ring topology. In order for this to work, each device needs Ethernet ports that are designed to be connected in this way. Not all devices have 2 ports, so they make an ETAP for this case. The ETAP has the 2 ports, which allow it to be connected in the ring, plus the 3rd port for the device.
Unread September 17th, 2019, 03:19 AM   #4
Poykim
Philippines
Poykim is offline
Why they dont use switch instead of ETAP
Unread September 17th, 2019, 04:15 AM   #5
cardosocea
United Kingdom
cardosocea is offline
Quote:
And miss out on the opportunity to overcharge their customers??
Unread September 17th, 2019, 08:43 AM   #6
iggy
United States
iggy is offline
iggy's Avatar
Quote:
I would disagree about price, they come in very handy for adding a device that does not have DLR.
__________________
I was doing some PLC Programming on my laptop while waiting on my grandmother to get ready to go out to lunch. She says she is ready, I tell her to hold on a sec I have to find a couple of bits, she reaches into her purse and pulls out a quarter for me.
Unread September 17th, 2019, 08:54 AM   #7
TheWaterboy
United States
TheWaterboy is offline
TheWaterboy's Avatar
A switch would consider the ring topology of DLR a loop. You could configure a managed switch with STP to allow for that or you could mirror a port, either of which then blocks the ring topology from working.
Even if that would work your managed switch now is as expensive as an ETAP but introduces more complexity and management into the network.
ETAP is a single purpose promiscuous tap so it has its place in the universe for older gear that needs to have redundant network connection.
Unread September 17th, 2019, 10:07 AM   #8
harryting
United States
harryting is offline
harryting's Avatar
ETAP is not just another 3-port switch!!!
DLR is using a completely different ring protocol than the standard STP or RSTP.
The problem with standard ring protocol is that they are too slow for industrial applications. It's not just Allen Bradley either. If you buy a N-Tron or Hirchmaan, they also have their own proprietary ring protocol. Therefore you have to match the type of switches carefully.
If you opt to use standard Cisco switch and do redundant ring or redundant star configuration. You have to carefully plan out the routing scheme. Often this will involve using ether-channels. You can't just plug multiple cable/fiber together and expect things will work out. The problem is, often they do "work" until a power bump and all the switches started to broadcast at the same time. Yes, I seen that scenario more than once.
Unread September 17th, 2019, 06:57 PM   #9
JaxGTO
United States
JaxGTO is offline
Be careful using these. I was just told by AB that is giving the blessing on a project I have coming up that the ETaps are causing problems when you use VLans and a 3 layer switch. So if you have those in your system, watch out.
__________________
I have to use Rockwell Software!
Unread September 18th, 2019, 09:23 AM   #10
harryting
United States
harryting's Avatar
Are you talking about KB 631448?
Basically it says ETAP doesn't support trunking. However, this doesn't mean the DLR can't be part of a VLAN, just means ETAP can't combine bunch of VLAN together.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Why is Rockwell putting VFD's on PLC network? lunenburger LIVE PLC Questions And Answers 21 December 5th, 2015 05:45 PM
1783-ETAP as a Supervisor Paul Rousseau LIVE PLC Questions And Answers 3 November 30th, 2015 05:00 PM
1783-etap House92 LIVE PLC Questions And Answers 1 May 27th, 2015 04:07 PM
RSLogix Axis Configuration tomizzo11 LIVE PLC Questions And Answers 11 January 14th, 2014 06:43 AM
ControlLogix ethernet Alan Case LIVE PLC Questions And Answers 6 April 2nd, 2012 04:07 AM
