plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Unread October 8th, 2019, 03:19 PM   #1
TheWaterboy
United States
TheWaterboy is offline
TheWaterboy's Avatar
How to change setpoints from 2 locations over telemetry
I'm sure this has been done but I keep tripping over myself.
You have a home location and a field location that are connected via polling radio telemetry.
How can I set up PLC code so that I can change a setpoint from either location? And how do you determine which one wins if both are changed at the same time?
I have bounced off this "2 Generals" problem and have not been happy with any work I have done on it.
Can someone share a flowchart or pseudo code or even just describe how to do this?
Unread October 8th, 2019, 03:45 PM   #2
ndzied1
United States
ndzied1 is offline
ndzied1's Avatar
This is pretty simplistic but it gets the point across. If the values are noisy, you'll need to set some change threshold before letting the new value take over.
If the output can't jump instantaneously, you'll have to add some ramping.
Enjoy:
https://youtu.be/5ReYA7-DmeA
__________________
nOrM
nOrM=Norman Dziedzic Jr.
I've never been to China but my phone has.
Unread October 8th, 2019, 04:32 PM   #3
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
I will have all the data that goes over the radio link in one big block. Some of the data is setpoints, other is just information going from point A to B.
The part of that block of data that is setpoints has an incoming and outgoing copy. The remote stations always work with (and write to) the outgoing data.
The incoming data is scanned for changes, and if an element of the incoming data is changed, I make a copy of it in a "handshake" file, and also copy it to the outgoing (working) data. I do this in a subroutine with a loop with indirect addressing so that it reduces the chance of a typo and I only call this subroutine when I know I have received data from the master PLC.
To know when I have received data from the master, I typically use the first setpoint as a "heartbeat" register and have logic that runs every scan comparing it to its handshake register. If it changes, I latch a bit, and reset the comms timeout alarm delay timer.
The bit that I latch will call the subroutine where the rest of the setpoints are checked for changes, the outgoing file gets updated and after the loop completes its cycle through the range I need covered, I unlatch that bit so I don't keep calling this routine unnecessarily.
In the master PLC, the same principle is applied. The outgoing data is considered to be the "live", active data used on its HMI and for control purposes, and changes are made to that outgoing data. The incoming data is checked against handshake registers (one for each setpoint) and if differences occur, the new value is written to both the handshake element and the outgoing register. Like in the remotes, I only run these checks when I know that the message has completed successfully, except here, I will ensure that both write and read messages are completed by looking at the MSG DN bits (not just the heartbeat transition).
The reason for this (as I am sure you are aware) is that radio telemetry is never 100%, so if for example, the master changes setpoint A from 0 to 1, and then the data gets sent. The remote receives it, updates its outgoing data, but the master fails trying to read it. Nothing is wrong yet, until it is changed again and the message succeeds, or if the write message fails on the next cycle after a subsequent change. Like you, I have shot holes in a handful of schemes and evolved my method to this point.
It is still not perfect. It is possible to get into a race situation when operators change the same setpoint at both master and remote and the polling happens to be in between the reading and writing, and the right combination of messages don't succeed. But this method has resolved the race condition more than 98% of the time for me. The big drawback is having to have basically three copies of each setpoint. I recently did a system with 15 remote sites, 9 of which needed remote setpoint controls, with about 20 setpoints at each of those sites. That ended up using a large percentage of the available space in a Micrologix 1400 acting as the master.
Having written all this out, I am not sure if I conveyed it well enough...
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants.
Unread October 9th, 2019, 08:15 PM   #4
TheWaterboy
United States
How funny - the first one was an actual 2 generals problem... Nice. It does have the problem of not updating both sides so each sees the others changes.
Okie
You are on the same path I am... a big block with part of it being monitored for changes. what a mess eh? But you have some additional checking that I'll look into. A race condition is pretty unlikely in my case, just have to do the best we can. Thanks to you both, I'll chew on this for a bit. I'll post my solution and see if you can poke holes in it.
Unread October 10th, 2019, 03:55 AM   #5
rdrast
United States
rdrast is offline
rdrast's Avatar
I had a customer once that wanted line speed control via single-turn pots.... the trick was, any of 8 pots could be used to control the speed.
My solution was to just monitor each pot, and if any one made a 10% change, latch that one as the speed source.
Worked great, and it was a suprisingly friendly, intuitive control system for the operators.
__________________
How to ask questions the SMART Way!
Look First, Ask Second!
Unread October 10th, 2019, 09:25 AM   #6
ndzied1
United States
ndzied1 is offline
ndzied1's Avatar
I like the 8 pots version solution. ...
https://youtu.be/2a6B0wA6tFc
__________________
nOrM
Unread October 10th, 2019, 05:28 PM   #7
TheWaterboy
United States
Yea, but still not ideal from a user perspective. Sliders in different physical positions... But still very interesting.
Whats the ??? doing in this?
Unread October 10th, 2019, 05:40 PM   #8
ndzied1
United States
ndzied1 is offline
ndzied1's Avatar
That is the down side of using FOR loops. At the end of the FOR loop, the value of i is actually 8. But the array only has values from [0..7] so the value with a callout of 8 is undefined.
And damn you, you had to keep harping on the sliders.... ;-)
https://youtu.be/_yTkMvyEWPY
__________________
nOrM
Unread October 10th, 2019, 05:41 PM   #9
ndzied1
United States
ndzied1 is offline
ndzied1's Avatar
The Tags in the project are:
Code:
PROGRAM PLC_PRG
VAR
	rCMD:		ARRAY[0..7] OF REAL;
	rWAS:		ARRAY[0..7] OF REAL;
	bLight:		ARRAY[0..7] OF BOOL;
	i:		INT;
	iGeneral:	INT;
	iGenDisp:	INT;
	rTemp:		REAL;
	rSET:		REAL;
	Smooth:		RAMP_REAL;
END_VAR
__________________
nOrM
Unread October 11th, 2019, 09:51 AM   #10
ndzied1
United States
ndzied1 is offline
ndzied1's Avatar
BTY, in my code, the "general" with the highest number station wins any races.
So if 4 and 6 go over the 10% threshold which I set up during the same PLC scan, 6 will "win" and take control. At least that seems like what will happen. Testing is left as an exercise for the student.
__________________
nOrM
Unread October 11th, 2019, 06:12 PM   #11
TheWaterboy
United States
LOL, but look at the magic you created...
Thanks Norm - this looks like fun - Ill try it over slow telemetry and see how that works.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Detect change in any element of UDT ASF LIVE PLC Questions And Answers 15 April 28th, 2016 10:55 AM
GE QuickPanel IP Address Change PLCPRO1 LIVE PLC Questions And Answers 1 April 20th, 2016 12:41 PM
PanelView Plus 7 Screen Change = Bit change? _Dock_ LIVE PLC Questions And Answers 3 October 13th, 2015 04:55 PM
Factorytalk view password reset button problem Nan LIVE PLC Questions And Answers 6 September 29th, 2015 01:16 PM
S7-413 wont change MPI adress. JesperMP LIVE PLC Questions And Answers 6 May 21st, 2003 04:02 PM
