compact logix l18 and control logix l63 msg instruction
Rahul Kumbhar
Mar 2017
mumbai
Dear all,
i am using compact logix l18er and control logix l63 i want to use message instruction in between this to i am not getting proper path to define in communication tab please help me i am trying to put message instruction in compact logix. my control logix is in slot no 0 and en2tr in slot 1 can you guys help me with the path for communication tab
The path will be...
2,192.168.1.111,1,0
Insert the actual IP address of the remote Ethernet module where I have it in red. Take care to match the .'s and ,'s exactly.
Specifying the path is made much easier if you put the modules into the I/O configuration tree, then you can just choose the destination device from the tree.
EDIT : If you enter the modules, change the "Module Definition" of the remote EN2T to be "Rack Optimisation - None", that way you will not consume a "connection".
What firmware are you using?
It would probably be easier setting up produced and consumed tags. Dependent on what information you are trying to pass between the 2 CPU's
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
52
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
93
I've blown the Output Transistor on the Output Card of a Compact Logix 1769-L24ER-QBFC1B It says J378. Does anyone know the replacement part...
198
243
I was wanting to see if anyone had any information on setting up a cub5 meter and getting the data to a Allen bradley PLC. I think i have the set...
129
