RS232 and connection between PLC S7-300 and Power Meter A1700 of ABB
Totochana
Guest
T
-Is it possible for us to connect PLC-S7 300 of Siemens to Power Meter A1700 of ABB? In my PLC System, there is a module PC 340 with RS232 port complied with point-to-point standard. And we also have A1700 with RS232 module (type MODVBR D). I tried to make a communication between them and realised that PLC can receive datas from A1700 in binary bits (with Step7 software). However, I couldn't distinguish which ones are voltagable bits and which ones are current bits...
So would you please help me to solve this problem?
-If this connection is impossible, can I replace PC 340 module with another module which can communicate between A1700 and PLC S7-300?
Thank you so much for reading this mail!
I am looking forward to hearing from you.
you can help me, i want read the data from A1700 user RS232?
help me comment?
Hi, I have a TWIDO TWDLCAA16DRF PLC that blinks its RUN led but doesn't startup. I have TwidoSuite 2.2 installed and I received a cable from a...
1,502
I'd like to connect my laptop AND proface HMI to an SLC 5/04 1747 L541 so I can look at the bit address of some of the HMI buttons. I don't have...
6,247
Hi everyone , Im from Portugal. I dont know if you can help or not but im little lost in this. I have a project in my hands that i need to...
3,256
OK so here is the setup; RedLion G3 HMI Panel is communicating over an RS232 port using Modbus RTU protocol to an AB Micrologix 1400 PLC. The...
3,125
Hi All, new member and hoping you guys have the answer!!! Im working on a Lauer HMI PCS 090 plus and Allan Bradley slc503 PLC setup thats all...
4,277
