forqnc
I've got an issue with a timer not being reset and it has me baffled.
I cut and pasted, from a working program, a section of code for resetting the back light on a NB5Q-TW01B HMI
With reference to the attached picture.
Rung 11 - bit W32.00 comes on when T21 has timed out (not shown). When the operator activates Scroll_NB, the RST_Backlight flag comes on and latches through NC T23.
Rung 12 - RST_Backlight activates T23, a 1 second timer.
Rung 13 - When T23 times out then it should reset RST_Backlight and T21.
Except it doesn't, RST_Backlight goes off but T21 does not get reset if the Scroll_NB input is less than 1 second.
If I keep Scroll_NB on for longer than 1 second then the coding works as it should. As I said this code is working on several previous machines, and while the rest of this program, for control, is different. The HMI coding is the same.
Any suggestions
Any suggestions
