CQM1H - Expansion Instructions / Download Error
GreenPuppy
Jun 2016
Bucharest
Hello, friends, newbie over here!
Looking for some guru help regarding a transfer error from CX to a CQM1H for the Expansion Instructions. My hair is starting to turn white from this Failed to download the expansion instructions. Check PLC DIP switch or settings so I'm gonna start wearing a wig soon if no mercy is shown.
Setup:
  • PLC: CQM1H-CPU51
  • CX Programmer 9.5 on Windows 10 x64, using USB-CN226, (9600; 1,7,2,E)
  • Switch 4 is ON/left position
  • Full switch positions: 1 OFF, 2 OFF, 3 ON, 4 ON, 5 OFF, 6 OFF, 7 ON, 8 OFF.
Tried:
  • Downloading only the Expansion Instructions, without the program and the settings
  • Resetting DIP switch 4 to default with ON/OFF movements a few times and then powering on
  • Powering the PLC with sw4 OFF
  • Checked sw4 contact on the board with a multimeter
  • Comparing the expansion instructions says not matching, but the program was written successfully and matching 100%.
Any ideas?
Thanks!
Thanks for your replies.
Yes, the communication is alright. I have written the program and the settings successfully.
I am starting to think that the CPU is not supporting the IOTC because when I replaced it with something else, all the 18 expansion instructions were written...
Any ideas are appreciated!
Hello, guys,
Could you, please, give me a hand with an example for an alternative writing for the attached IOTP? I'm kinda new to this whole stuff and this IOTP guy is hurting my head :)
Referenced to SYSMAC CQM1H - Dedicated IO Units W238-e1-10, pdf page 281
Thanks!
Hi Everyone, I have a customer that needs a CQM1H (CPU51) replaced. They purchased the processor new-old-stock from a source they found online...
345
I have an Omron CQM1H-CPU21 and a NS8-TV00B-V1, I have followed the manufacturer's spec on how to set this up and all I got is the HMI is trying...
872
Hello maybe someone can help me, I have omron CQM1H PLC with CLK21 (Controller link module) and SCB41 (Serial module connected with NMB CSD-891B...
539
I need a CQM1H-CPU51 to talk to my Red lion Da30D i just need to read the status of some I/O and maybe read some data registers but I cannot...
1,158
Hello, I need some help to convert PMCR instruction from Omron CQM1H that using CQM1H-SCB41 to CJ2M using CJ1W-SCU4, The problem is on the old...
841
