insufficient resources exist to support alarm and event functionality
Engrlife
Aug 2017
British Columbia
41
I am getting the following error on factory talk and cant find any explanation for it "insufficient resources exist on WTP_PLC to support alarm and event functionality.
Any suggestions on what it could be? I have an compact logix 5332E PLC. My first thought was communication issues as there was issues over night, but those are resolved and scada is getting data but I cant clear the alarm
Is "WTP_PLC" the name of your PLC? Is there enough memory available in your PLC?
Based on what I found in the Rockwell Knowledgebase, this can be caused by the PLC running out of memory, or insufficient disc space, or creating too many backups of the FTView application.
FYI for anyone having this problem the only thing I could do to fix this was to power cycle the PLC
I've had the issue when your PLC is out of memory. It was an old PLC that had a lot of people on it over the years. Even doing simple online edits was starting to get dodgy.
I upgraded from a L61 to L72 and it was fine after (I went up to the 72 because we were removing 51s and the 61 could be used in its place).
edit - old as in it went from original project to several upgrades and a lot of customer features added by the original installer and others.
Insufficient resources exist on SOME_CLX_PLC to support Alarm & Event functionality. Hi All AB question. Please help me sort out this error in FT...
2,228
Dear Experts We are using 3 control logix systems (3 controllers for three different areas) on a cement plant. On two Ares tags are almost...
2,519
We have purchased Controllogix system for our white cement plant at Kohat. And we are facing problem in communication since we purchased it. Our...
2,693
S7/TIA v18: Status Message "Insufficient memory space on the memory card"...... Hi, Please can anyone help me with this? I've been trying to...
27
2,379
Hi, We had a power bump last night. After we got everything back up an running I had an alarm come in. Unable to subscribe to alarms from...
2,531
